Author Topic: Trunk light identification  (Read 4978 times)
Offline Oz390
« on: May 05, 2013, 12:58:20 AM »
I have two trunk lights, supposedly correct for a '68, but ... different...
One has a green wire with yellow stripe, red bullet connector.  No marking on wire but C8ZB-13A756-A on metal socket/mount.  The second has a slightly different socket/mount, with no stamping, but C8OB-13A756-1A FoMoCo stamping on the black wire.
Is either correct for a 68 Mustang?
« Last Edit: May 05, 2013, 01:02:19 AM by Oz390 »
8R03S : 76A I 2A 15M 72 5 U
Re: Trunk light identification
« Reply #1 on: May 05, 2013, 01:15:47 AM »
zb mustang  ob torino
Offline tim_morrison82
    • Click Here for My Project
« Reply #2 on: May 05, 2013, 01:26:46 AM »
the older looking one is correct for 68
« Reply #3 on: May 05, 2013, 02:33:06 AM »
Square mounting edge is the first identifier between these two
Offline rockhouse66
« Reply #4 on: May 05, 2013, 07:57:21 AM »
Do both of these have the same size bullet connector and does the bullet size match the female connector on your harness?  I have run into some mismatch differences in this area on my '69.  Maybe the size changed between '68 and '69?
'66 GT FB
« Reply #5 on: May 05, 2013, 08:53:41 AM »
Ford bullet connectors are all the same size, with exception of 64.5-67 door jambs and 68 fuel line/switched courtesy light harness on right-hand side.
Offline TLea
« Reply #6 on: May 05, 2013, 10:07:57 AM »
The only difference I've ever seen between 67-70 Mustang trunk lights is wire lead and mounting bracket. Good to know as you can find less popular ones like torino/others and switch lead/bracket if yours is not working
Offline rockhouse66
« Reply #7 on: May 05, 2013, 09:34:33 PM »
I know you are probably right Randy, but the bullet on this one was too big for the female pigtail in the harness.  I now stay away from ones with red boots just in case!
'66 GT FB
« Reply #8 on: May 05, 2013, 10:01:01 PM »
Every once in a while I run across a difficult male bullet, but I can look real close and find either the male or the female mate have been crimped a bit making it hard to insert.  I use a drill bit to round out the female by pounding it in, and use a crimping tool to make the male round again.  Sometimes, it is just a bitch to put together....
« Reply #9 on: May 06, 2013, 12:45:36 AM »
If you're really interested, the more common bullet connector size Ford used on its early Mustang electrical connections is 0.187in dia. (the door courtesy light switch uses a 0.156in dia.). This comes in handy if you need to add some "special" electrical devices and are not in the cut and splice mindset (make a male-female jumper with another lead crimped to either the male or female jumper connector as in a "Y" to your "special" device).
Another point of trivia, is most of the wire color codes Ford used on its wires in 1964 was used on its vehicles in 2000. That might continue into the current year, I haven't had to tear into a new car.
« Reply #10 on: May 15, 2013, 07:53:44 PM »
Stumbled across one in a 67 coupe today near the old Kelsey Hayes turned to Ford plant in Monroe MI - see pics below.  Car will be parted out.
Was this a distinct and separate option for 67, or something part of a "convenience group"?  The car has a C code/auto, interior decor (red), clock, A/C, deluxe seatbelts/warning light, upper and lower consoles.  No convenience control group though.
« Reply #11 on: May 15, 2013, 10:48:46 PM »
In 67 it was part of the Courtesy Light Group option which also included the under hood light and glove box light.
Marty
