Author Topic: 69 Dearborn Mach 1 Heater Motor Ground  (Read 2481 times)
Offline G Wood
« on: May 03, 2013, 11:13:18 AM »
Does any one have a photo of the correct location to mount the ground for the heater motor and what the correct fastener is for the ground.
Re: 69 Dearborn Mach 1 Heater Motor Ground
« Reply #1 on: May 03, 2013, 03:01:23 PM »
Non Ac I'm guessing - will look for a clear picture of a Dearborn install just in case
Offline G Wood
« Reply #2 on: May 03, 2013, 03:13:52 PM »
Non-AC, thanks Jeff.
« Reply #3 on: May 03, 2013, 05:24:29 PM »
Here are a couple of cars - both locations match
Offline G Wood
« Reply #4 on: May 03, 2013, 06:45:21 PM »
Thanks Jeff. The puzzling thing on my car is that I can find no evidence of a hole in that location. I will look again tonight but based on previous inspections, there is no evidence of a hole that has since been filled.
Offline app01
« Reply #5 on: May 03, 2013, 09:48:43 PM »
I just asked this same question on the boss forum earlier this week. On my May 70 Dearborn Boss 2, the 3 dimples under the hinge, where one is normally drilled for the ground screw, none were drilled. Also after  stripping all of the metal, there was no sign of anything being filled. I did find a 3/16" hole about 6" below the hinge.
I wonder if they ever just drilled a hole in the general area.
Currently own:
1962 Corvette 340hp
Previously Owned:
1970 Mach 1 (my 2nd car)
1989 GT
MCA #62598
www.PalmieriConcepts.com
« Reply #6 on: May 04, 2013, 12:00:52 AM »
Hmm - panel has a good date on it and that inner panel hasn't been replaced?
Now focusing on  your cars specific time period to see if there was  change taking place - or an odd worker that choose to attach it elsewhere I found
Attached in the same general location
9F145937
9F155672
9F156186
9F156763
9F157891
9F171870
Appears to be traveling in the other direction but the example is a "restored car"
9F168857
Sorry no matches - also too early to check Boss's and Shelbys will not help much :(
Offline G Wood
« Reply #7 on: May 04, 2013, 11:56:23 AM »
Jeff:
After spending more time searching in the area of the photo, it looks like the hole has been welded and filled, but there is evidence it is there.
Thanks for the photo.
« Reply #8 on: May 04, 2013, 07:37:00 PM »
Jeff:
BINGO !   :)
Offline app01
« Reply #9 on: May 05, 2013, 06:24:47 PM »
Same here and found it.
As it turns out the hole was where it should have been and between engine bay paint and  some sound deadner under the wheel well it filed up. A little poking with an awl  where the dimples ate revealed the hole.
Currently own:
1962 Corvette 340hp
Previously Owned:
1989 GT
MCA #62598
