Author Topic: 70 Boss 302 - Rev Limiter wiring clamps on valve cover front bolts  (Read 4122 times)
Offline app01
May 70 Dearborn B2.
In reference to the clamps that go under the front valve cover bolts that secure rev limiter wiring harness, I have the 2 following questions:
1. At the end where the bolt goes through, is the clamp squared off, or is it clipped at the 2 back corners? I have what I think is an original one and it is squared, yet most of what I see, as well as the repops are clipped.
2. For the rev limiter harness, is there  just one clamp (if so which one?), or do both the front bolts have a clamp? The assembly manual shows one on the lower bolt, and the upper bolt is obscured in the drawing, however most examples I see has the clamp on the upper bolt.
Thanks again,
Tony
« Last Edit: April 28, 2020, 08:47:52 PM by J_Speegle »
Currently own:
1962 Corvette 340hp
Previously Owned:
1970 Mach 1 (my 2nd car)
1989 GT
MCA #62598
www.PalmieriConcepts.com
Offline bkarchy
Re: Rev Limiter wiring clamps on valve cover front bolts
« Reply #1 on: May 02, 2013, 12:03:13 PM »
Would someone post a picture?
Thanks...............Ben
« Reply #2 on: May 02, 2013, 08:29:19 PM »
Clamp location
Clamp style - not sure if there were other versions but here is what was installed originally on this - approx May - Boss
Offline bkarchy
« Reply #3 on: May 02, 2013, 09:36:05 PM »
YOU the MAN Jeff ..............Thanks.................Ben
Offline app01
« Reply #4 on: May 02, 2013, 10:06:23 PM »
Perfect. Thanks Jeff. Just what I needed.
Tony
Currently own:
1962 Corvette 340hp
Previously Owned:
1989 GT
MCA #62598
Offline Dads Boss
« Reply #5 on: May 03, 2013, 07:56:53 PM »
Where can you get one of these clips?
Offline app01
« Reply #6 on: May 03, 2013, 09:43:13 PM »
Currently own:
1962 Corvette 340hp
Previously Owned:
1989 GT
MCA #62598
Offline Dads Boss
« Reply #7 on: May 11, 2013, 07:52:09 PM »
Thank You I ordered one. Best Regards
Offline Oneowneraquaboss
« Reply #8 on: May 18, 2013, 10:48:45 AM »
Hi guys, I'm a real newbie to this site but not to the car, I've had my BOSS 2 for a long time. In fact I ordered it new back in 70. It was the only way I could get my favorite color, and rear gears. To the point though, I agree with Jeff on the location of this wire clip (the OE clips are notched corners) but feel we should mention that most B2s came with 2 more (sometimes 1) of these clips on the top two bolts of the same valve cover to carry the engine feed and the carb solenoid wires. The best thing is, of the three pictures Jeff posted the bottom picture shows a seldom seen part. If you noticed the green oil pressure sender unit you win 10 points. I believe that is a C8AZ-9278-A and is unique to tach dash cars. It was OE on B2&9s and not serviced very long. Other than my car I rarely seen one. This is not written in stone and is a recollection of timely guy and I'm open to other observations. Thanks for reading. Rich
0F02G192781 - I ordered new in 1970
Paint code 'F' - 1 of 9 BOSS 302's produced in this color
Axle code 'W' - 1 of 230, 4.30 Detroit Locker cars with oil cooler
Magnums, Shaker, Deluxe interior, P/S and Spoilers
HAPPY MOTORING
Offline Dads Boss
« Reply #9 on: May 18, 2013, 04:46:46 PM »
OK I'm ordering two more clips, makes sense for the engine feed. Thanks Jeff and Oneowner. Oneowner I would love to see pictures of your car. Lucky Man, I'm jealous.
« Reply #10 on: May 21, 2013, 12:14:34 PM »
Rich you are correct about the oil temp sender but there were 2 types both c8az #s & the green ones I see on 428 cj cars but the B9s I see the taller black type.  I think its a vendor to engine plant thing.
