HOW does the rest of the car fit up, like the door to qtr. panel gaps, trunk lid to qtrs. etc..? I would not do any fitting are welding with the car on jack stands supported by the frame rails, If your car has the suspension in it, have the car on it's wheels are support with jack stands at the rear axle housing and front lower control arms. I would first fit the trunk lid to the rear body and see how it shuts and seals and fits up. As for brass there was some limited use around corner seams from the factory but the edges around the qtr. panels and rear x member are all spot welded. If you can upload some photos this may help too. I have noticed on most models I see the rear body panel and bumper mount brackets are not perfectly aligned, however not as extreme as 1/2 inch or more. chris
