Author Topic: What grease will stick at the door hinges?  (Read 1699 times)
Offline MWM
« on: April 29, 2013, 10:55:52 AM »
Seems like a couple of weeks ago I had to lube my hinges, now they are dry again. This is a fresh rebuild with new roller, etc. What works best to keep the hinges greased?
Thanks!
Re: What grease will stick at the door hinges?
« Reply #1 on: April 30, 2013, 12:02:33 AM »
For the hinges white lithium but don't go crazy ;)  is my choice
Once sprayed work the door back and forth to move the product into all the crevices
« Last Edit: May 04, 2013, 07:32:42 PM by J_Speegle »
« Reply #2 on: April 30, 2013, 12:22:06 AM »
And the choice of the factory as the preinspection sheets seem to indicate.
Offline RadBOSS
« Reply #3 on: May 04, 2013, 01:51:50 AM »
I think the white lithium dries up too quickly and leaves a mess,  and does not flow and penetrate the joints.  3M has a aerosol grease for lubricating any kind of hinge (hood, doors, latches, etc).  With the red nozzle extension you can apply with surgical accuracy.  It sprays out thin and wet, flows to those tight areas,  then coagulates,  any overspray is easy to wipe up.  Should be able to find the 3M (preferred) or other at most part stores.
