I'm not 100% sure, but I believe they only came on convertibles.
OK--but why only on convertibles? In case you're driving in the rain with the top down they give you insulation from a possible 12V shock when you dim your lights?!
I put the cap on all my cars, it looks better than a bare steel switch. I believe the plastic grommet that goes in the hole in the carpet around the switch is an "aftermarket only" item but I use them too.Jim
