Author Topic: C8AZ-12370-A vacuum advance  (Read 2219 times)
« on: April 17, 2013, 11:42:31 PM »
Could someone please verify the application of a C8AZ-12370-A vacuum advance?  I'm having a hard time looking it up in the MPC and other reference material I have.  Best I can tell, it's the exact same piece as used on a 68-69 428 cobra jet except it doesn't have the HP6 stamping on it.  Pics attached...
Offline rockhouse66
Re: C8AZ-12370-A vacuum advance
« Reply #1 on: April 18, 2013, 09:12:03 AM »
Charles - as you know, it looks identical to the CJ part but is calibrated differently.  I believe it is 4-speed big block but not CJ.  The B12 and DD-236 are the key application numbers.  There is another that also looks just like this but marked A12.  I think it may be 4-speed small block.
'66 GT FB
Offline rockhouse66
« Reply #2 on: April 23, 2013, 05:43:10 PM »
Charles - more info (maybe ???).  I have a huge Autolite book that goes through 1968.  The DD-236 vacuum advance is listed for several applications, but the most common is '68 302 4-barrel w/IMCO (Mustang, Comet, Cougar).  There are a couple of others - truck w/390 and Bronco w/289.  The odd thing is that I also have a NOS DD-236 and mine is marked A12, whereas yours is marked B12.  Confusing.
BTW, the correct CJ 4-speed vacuum advance (with the HP6) is DD-239.
'66 GT FB
« Reply #3 on: April 23, 2013, 05:54:14 PM »
Thanks.  Talked to Tim O'Connor, he thinks the part is in the wrong box.  Ended up selling it to him.
