Author Topic: Gas filler neck rubber hose clamp orientation  (Read 1651 times)
Offline app01
« on: April 17, 2013, 12:09:49 PM »
Dearbiorn, May 70 B2.
Is there an orientation for the 2 clamps that are on the rubber hose between the tank and filler neck? For example are the clamps orientated to the side, towards the front of the car, etc? The assembly manual does not show that level of detail, so I suspect it may be a plant thing.
I still have my original hose and it is in very hood condition. I also noticed that the clamps have the tightening screws going opposite directions (can tell its been that way for a long time given the impression into the rubber). is this common?
Tony
Currently own:
1962 Corvette 340hp
Previously Owned:
1970 Mach 1 (my 2nd car)
1989 GT
MCA #62598
www.PalmieriConcepts.com
Re: Gas filler neck rubber hose clamp orientation
« Reply #1 on: April 17, 2013, 03:38:24 PM »
     This is how it looks on my car.  Interestingly enough the lower screw is installed opposite of the upper.  Brian
Offline app01
« Reply #2 on: April 17, 2013, 04:37:05 PM »
Thanks Brian, that is the same  as mien with the screws  going opposite directions.
Tony
Currently own:
1962 Corvette 340hp
Previously Owned:
1989 GT
MCA #62598
« Reply #3 on: April 17, 2013, 08:23:41 PM »
Though allot of the ones I have are of cars with the evap system did find a couple of 49 states that might help
Just the bottom  clamp. Same direction as the clamps below
Top and bottom both about the same spot and same direction - looks like tails of the clamp are facing towards the passenger side
Offline app01
« Reply #4 on: April 17, 2013, 08:49:51 PM »
Thanks folks. This is helpful.
Currently own:
1962 Corvette 340hp
Previously Owned:
1989 GT
MCA #62598
