Author Topic: Crossover Plate on convertible  (Read 2555 times)
Offline MyRed66GT
« on: April 14, 2013, 09:52:22 PM »
Are these typically bare metal, black or red oxide. I thought they were installed after underbody was painted. San Jose assembled.
Re: Crossover Plate on convertible
« Reply #1 on: April 14, 2013, 10:31:20 PM »
What year???? Since you provided the plant...
If I'm guessing based on your screen name it's Semi-gloss black (glossier than engine pulleys and the lot)
Offline MyRed66GT
« Reply #2 on: April 16, 2013, 11:55:15 PM »
Thanks Jeff thats what I thought...yes 66 GT...
Offline MyRed66GT
« Reply #3 on: April 27, 2013, 08:39:25 AM »
When I dug this part out of the barn it still had the factory black paint on it. Just had the painter freshen that up. Thanks again!
Offline 66RavenGTCoupeAgain
« Reply #4 on: September 19, 2016, 06:19:36 PM »
Would this be the same for a Oct 20 64 built SJ car too Jeff?
66 Metuchen NJ  GT Coupe
Raven with Deluxe Black Int 289 A Code C4 PS Tinted Windows (Green) Dealer installed Rear Speaker
6T07A1612## Dec 65 Build
65 San Jose CA Convertible Rangoon Red with White Int and Power Top with plastic rear window 289 C Code C4 PS PB AC Fog Lights
5R08C1496## Oct 64 Build
« Reply #5 on: September 19, 2016, 06:29:18 PM »
From the ones I've seen  yes - semi-gloss black
« Reply #6 on: July 19, 2019, 10:46:10 PM »
Thanks Jeff. Can you confirm the correct way of installing it please? Does the flat/straight end go to the rear and the raised/indented end go to the front?
« Reply #7 on: July 19, 2019, 11:41:13 PM »
Thanks Jeff. Can you confirm the correct way of installing it please? ......................
Here.s a picture of a car built just a little while before your car same plant
Its is posted in the labeled  Early 66 SJ Convertible - Unrestored Picture Thread in the picture section of the site  ;)
Marked U6
If you can't tell the front end of the car is to the right in the picture
« Last Edit: July 19, 2019, 11:45:02 PM by J_Speegle »
