Author Topic: 67 San Jose sound deadener question  (Read 1776 times)
Offline rocnhrse
« on: April 14, 2013, 09:06:10 PM »
does anyone have photos of where the sound deadener applied in the trunk area in the San Jose plant in the first week of April of 67
I forgot to take photos( should have a camera in my tool box ) Also the lower area of the inner wheel well were there was no sound deadener
how did they do that, if there is over spray on frame rail ?
thanks John
« Last Edit: June 30, 2016, 04:03:01 PM by J_Speegle »
67 mustang  GTA  S code fastback  San Jose  April 67
Re: sound deadener
« Reply #1 on: April 14, 2013, 10:37:40 PM »
Will find some and post
Over spray of sound deader on the rear frame rails behind the wheelwell is normally the results of the worker, applying sound deadener to the rear wheel wells finishing there pass at the end. Normally they started at the front edge (on the frame - normally three passes on the lower section) and finished after the rear edge stopped. This allowed product to flow into that area.
You'll find body color and pinch weld black out there too ;)
Re: sound deadener
« Reply #2 on: April 17, 2013, 10:57:38 PM »
As far as the trunk looks like ,up to 5  vertical passes of the wand is fairly typical for one of the workers during that period. Fairly heavy sag or build at the bottom edge
As for the other part of the question... I might have misunderstood where you were describing Lets try again :)
Take some time to read the discussions about reproducing the original look for the sound deadener... they will be helpful
Offline rocnhrse
Re: sound deadener
« Reply #3 on: April 19, 2013, 01:04:42 PM »
thanks Jeff, I am on the right track after reading all posts, and your photos, I want to be neat but
all the applications look sloppy, I am surprised we didn't complain in the sixty's
Re: sound deadener
« Reply #4 on: April 19, 2013, 01:15:19 PM »
Its the trunk....... drips and runs in the paint there were fairly common. Interior's and exterior's  were much more important to the inspectors and customers ;)
