Author Topic: Shock Tower Support Bracket question  (Read 2097 times)
Offline Jays66gt
« on: April 13, 2013, 08:58:20 AM »
Looking around at other Mustangs I see that the export braces are one solid piece. But mine is not. It's bolted together and welded to the shock tower. Is mine original to the car? Are the originals supposed to be bolted together? Obviously a solid piece is stronger.
BTW, that picture is old.  The Edelbock carb and ugly fuel filter is LONG gone!
« Last Edit: October 11, 2022, 05:20:44 PM by J_Speegle »
1966 GT
6R07A105XXX
San Jose car delivered to Denver in September 1965.
Re: Shock Tower Support Bracket question
« Reply #1 on: April 13, 2013, 09:22:03 AM »
that is not an export brace. it is the stock factory bracing. all mustangs had that. export brace is as you stated a one piece item bolted above the stock brace after it is removed.
« Last Edit: October 11, 2022, 05:20:52 PM by J_Speegle »
Offline Jays66gt
Re: Export Brace question
« Reply #2 on: April 13, 2013, 09:30:41 AM »
All Mustangs?  I've seen many with no bracing at all.  But thanks for letting me know this is how it should look.
Jay
1966 GT
6R07A105XXX
« Reply #3 on: April 13, 2013, 05:43:49 PM »
Yes, all Mustangs received braces.  They of course vary from year to year, and in some cases have additional holes along the brace to strap hoses to make for a large number of variants.  Export vehicles, Shelby's, and perhaps those with competition suspensions got the once piece export brace in lieu of the standard pair of individual ones.
« Last Edit: October 11, 2022, 05:21:00 PM by J_Speegle »
« Reply #4 on: April 13, 2013, 11:19:56 PM »
....................... perhaps those with competition suspensions got the once piece export brace in lieu of the standard pair of individual ones.
Never seen a Comp suspension car with an export brace and build sheets do not indicate they were installed ;)
« Last Edit: October 11, 2022, 05:21:06 PM by J_Speegle »
« Reply #5 on: April 14, 2013, 08:10:28 AM »
Thanks for the clarification on the competition suspension - I used the term "perhaps" because that is an area I have not studied, and figured that someone that reads this post later on might wonder about it.
I suppose I should also mention that in other posts and sites there has been some discussion, with pictures, of some exported vehicles that might not have received the export brace.  I would think, though, that the export brace should be "expected" to be found on exported and Shelby versions of the Mustang, and expected to not be found on others.  Exceptions, even if documented, probably should be respectfully questioned.
« Last Edit: April 14, 2013, 08:21:20 AM by 67gta289 »
« Reply #6 on: April 14, 2013, 05:50:51 PM »
Understand and that's why I responded so that it was not left hanging ;)
Would guess that the pictures were of 65-66 "export " cars ... we've seen a couple of made "Export " cars at shows that unfortunately some one sold a buyer on :(
+1
« Last Edit: October 11, 2022, 05:21:17 PM by J_Speegle »
Offline MWM
« Reply #7 on: April 18, 2013, 03:52:46 PM »
What finish is the export brace? Gloss, flat, something else?
« Last Edit: October 11, 2022, 05:21:24 PM by J_Speegle »
« Reply #8 on: April 18, 2013, 06:02:04 PM »
None of the above ;)
Semi-gloss black - glossier than engine compartment walls or engine pulleys
« Last Edit: October 11, 2022, 05:21:33 PM by J_Speegle »
