Author Topic: 1969 Standard Interior 4 Speed Shift Knob  (Read 3843 times)
Offline 69GTconvert
« on: April 09, 2013, 10:18:41 PM »
Since my Mustang originally came with a 4 speed and standard interior, would my shifter knob be woodgrain with a white face and blue stripes or a black round one?
If it is the black round knob, would it be  the same knob that was used in '67 and '68?
Thanks.
George
Georgia
1969 Mustang GT Convertible
390 4V, Close Ratio 4 Speed
Royal Maroon - Black Standard Interior w/ High Back Seats
Re: 1969 Standard Interior 4 Speed Shift Knob
« Reply #1 on: April 09, 2013, 11:54:52 PM »
Black one normally- believe its the same as 67-69. Reproductions are different from originals (surprise)  but will fill a need
Offline 69GTconvert
« Reply #2 on: April 10, 2013, 07:52:33 AM »
Thanks Jeff. How do the new knobs differ from the originals?
George
Georgia
« Reply #3 on: April 10, 2013, 07:39:36 PM »
Can't find the thread but from memory (don't have both at home to compare) I recall the thread insert
Offline 1Hotboss
« Reply #4 on: June 21, 2014, 07:26:28 PM »
Would like to revisit this question how to tell an original black shifter knob from the repos....Thanks
Also the deluxe woodgrain with white top and blue stripes Thanks
« Last Edit: June 21, 2014, 10:24:15 PM by carlite65 »
« Reply #5 on: June 21, 2014, 10:27:09 PM »
     This is the knob on my early 69 Mach 1.  Can only assume that is OE.  I have heard some of the things to look out for are; the chrome outer ring, the shift pattern lay out in relation to the blue stripes and the flat top 3.  Brian
Offline jimhib
« Reply #6 on: June 21, 2014, 11:32:31 PM »
Brian, You are correct, I have the same ball on my shifter and it is the original. Never saw a 69 with a black ball unless it was a three speed.
« Reply #7 on: June 22, 2014, 05:26:50 PM »
Isn't there a different in the thread insert between originals and reproductions. Will have to see if I have one of each to compare
Offline rharlan
« Reply #8 on: June 22, 2014, 07:54:01 PM »
The ball on a 69 Mach 1 with three speed is woodgrain  with white face, blue strips and shift pattern.
Bob
Original owner 69 Mach 1 H code 3spd
Offline jimhib
« Reply #9 on: June 22, 2014, 10:58:48 PM »
 I thought we were talking Sportsroofs, not Mach I's. The woodgrain would be correct on a 3 speed Mach.
« Reply #10 on: June 23, 2014, 10:46:46 AM »
also 3-speed knobs & shifter handles are smaller threadedin area & don't interchange with 4-speed knobs & handles that are a bigger siize thread
Offline TLea
« Reply #11 on: June 23, 2014, 12:37:02 PM »
Insert on repops is brass, OEM are steel. The flat top 3 isnt necessarily indication of repop. Flat top was used 68-early 69 then round top 3 continued into service. Repops copied the service with round top 3
« Reply #12 on: June 23, 2014, 12:51:38 PM »
     On this particular knob next to the steel insert, in the plastic edge, is a cast and raised # 2.  Brian
« Last Edit: June 24, 2014, 12:34:19 PM by Brian Conway »
« Reply #13 on: June 23, 2014, 10:51:43 PM »
[quote author=TLea
   All the while carrying the same C8OZ-7213-F part number ?  Brian
« Last Edit: June 23, 2014, 11:15:16 PM by Brian Conway »
