Author Topic: 1970 parking brake cable asembly  (Read 1543 times)
Offline app01
« on: April 09, 2013, 05:38:12 PM »
May 1970 Dearborn B2
On the 2 rear parking brake cable assemblies where the cables come out from the rear wheel  backing plates, should there be a small rubber seal  (bell shaped) on the cable housing? If so, any idea where I can purchase just those seals?
The front cable  from the foot lever should have one, correct?
Tony
Currently own:
1962 Corvette 340hp
Previously Owned:
1970 Mach 1 (my 2nd car)
1989 GT
MCA #62598
www.PalmieriConcepts.com
Re: 1970 parking brake cable asembly
« Reply #1 on: April 10, 2013, 12:23:33 AM »
Yes & don't know how you would replace it without taking cable apart.
Offline app01
« Reply #2 on: April 10, 2013, 10:10:46 AM »
My thought is that they should slip over the cable end(that small ball). and slide down the cable. Keep in mind that I am not referring to the one that is at the backing plate, but rather the end  of the cable where it attaches to the frame.
Tony
Currently own:
1962 Corvette 340hp
Previously Owned:
1989 GT
MCA #62598
« Reply #3 on: April 10, 2013, 02:13:46 PM »
I never tried that but after 40 years that thin rubber boot dryrots & cracks & I am afraid you would rip the hole to big removing or replacing boot.  I have several cables at shop I replated but boot is bad & never looked for a source of someone selling boot separately but would be worthwhile looking into as that & the rubber sheathing tub ing is all that goes bad on cables unless they are pitted from rust.
