Author Topic: "Paint OK" markings 66 NJ Mustang  (Read 15087 times)
Offline Hipo giddyup
Re: "Paint OK" markings 66 NJ Mustang
« Reply #45 on: March 20, 2018, 02:01:51 PM »
For paint inspector what you report would follow the typical pattern we see- One inspector for the unibody - one for the panels shot off the car but located in another section of the plant
So I have some input to this thread as well. I just picked up a matched pair of fenders off of an early 66' built car, (maybe around late Oct./ early Nov. 65), pretty sure from NJ (has the Martz stamp). The funny thing is the driver's side fender is stamped "MARTZ" where as the passenger side fender is stamped "KRRWIN" or "KERWIN" (it really looks like two R's)?????? Does this mean one inspector was on one side, the another inspector on the other?  :o Or maybe someone left in mid stream to take lunch and the other filled in?? LoL
 Could it be possible for two different stamps on each of the fenders??
Dr. side "MARTZ"  stamping 10 23 D2
Pass. side "KRRWIN"  stamping 10 27 3
« Reply #46 on: March 20, 2018, 02:44:21 PM »
............... Could it be possible for two different stamps on each of the fenders??
NJ inspection stamping practices were different from both he other plants both, it appears, in style and when they were placed on the car/body. Did you get a good look at the top section of the stamp for both names as they may have been different stamps (purpose) from one another sort of similar in practice to early Dearborn stamps from 64-65 where they were for other things other than just the paint
Offline sgl66
« Reply #47 on: March 20, 2018, 03:25:25 PM »
Went back to post #37 and corrected it to say KRRWIN who stamped the drivers side hood in that example so we can probably conclude he wasn’t stuck on the passenger side only
« Reply #48 on: March 20, 2018, 04:10:50 PM »
 If I am understanding correctly Jeff, I'm guessing you are referring to a "Body" OK, etc.? For the final assembly? Unfortunately i cannot make out what is above the KRRWIN stamp.
sgllbs: Thanks for the response. So you believe it does say KRRWIN as well?? I thought it might have also been a smearring of the stamp?
Offline sgl66
« Reply #49 on: March 20, 2018, 05:25:20 PM »
sgllbs: Thanks for the response. So you believe it does say KRRWIN as well?? I thought it might have also been a smearing of the stamp?
Yes looks like KRRWIN to me. Also look at reply #2 in thread, Looks to be a KRRWIN on the same date stamped fender
« Reply #50 on: March 20, 2018, 06:11:57 PM »
Just something that should be mentioned - not to suggest that the ones being discussed here are not legible
There were two inspectors who's stamped name started with "K" in 66. Clearly looks like that name includes two or three "E"s in it
Amy even be an possibility that its the same inspector but the first version wasn't correct or to his likely so it was remade and used later in the year. Might be a stretch - just looking at the possibilities.  Example below is from 6T16xxxxx
So on stamps that are not in the greatest condition the two can be confused
« Last Edit: March 20, 2018, 06:20:28 PM by J_Speegle »
Offline sgl66
« Reply #51 on: March 20, 2018, 08:07:02 PM »
Reply 2 is from car 1612xx and clearly ends with the letter N. Reply 37 is from car 229xxx and is clearly K_RWIN so switching to KEEFE later in the year is unlikely.
Hard to tell if the stamps are worn or clogged with paint or if they loaded it with paint and stamped 2 or 3 places before reloading.
« Reply #52 on: March 20, 2018, 08:14:07 PM »
Given those findings I agree. Just looking for possibilities but obviously that one failed
May be an issue some times but at least in the clear stampings where the letter made full contact it appears that we have two inspectors at NJ in 65-6 that started with the letter "K"
Offline NEFaurora
« Reply #53 on: June 01, 2018, 08:07:11 PM »
Found some more good ones in my files....Last number on VIN# withheld....to protect the innocent...since they are Sprint 200 registry members.  The last one is very interesting... #157 Painted on the Upper Hood (Metuchen Plant Quality Control??).  These are all from Original unrestored cars.
:o)
Tony K.
MCA#70001
