Author Topic: Fan and Clutch for a 1969 390  (Read 2898 times)
Offline 69GTconvert
« on: April 04, 2013, 11:20:48 AM »
I own a 1969 Mustang convertible with a 390. The original fan and clutch are long gone and I am trying to replace them but I'm not sure which part numbers I would need. It looks like there were 2 different fan clutches available for my Mustang; C8OE-B or C8OE-C. Can anyone tell me which one would apply to my car?
Also, which fan would I need? Would it be a C8OE-B fan or something else?
Here is some info on my Mustang if this helps:
- Built 4/8/69 in Dearborn
- Four speed
- Non-A/C
- Power steering
Thanks.
« Last Edit: April 04, 2013, 11:46:55 AM by 69convert »
George
Georgia
1969 Mustang GT Convertible
390 4V, Close Ratio 4 Speed
Royal Maroon - Black Standard Interior w/ High Back Seats
Re: Fan and Clutch for a 1969 390
« Reply #1 on: April 04, 2013, 09:37:26 PM »
Looking at the 72 MPC it shows the C8OE-A (same listed for all 68 390 applications in a 68 MPC version) for AC and the -B or -C as non AC applications
Can't locate my assembly manual copy to cross check
« Reply #2 on: April 04, 2013, 10:34:54 PM »
My documentation (second hand and only for 1968---no info for 1969) shows the -b and -c as equivalent applications for all that didn't have A/C or thermactors.
« Last Edit: April 04, 2013, 10:36:26 PM by midlife »
« Reply #3 on: April 04, 2013, 11:06:28 PM »
What 68 390 didn't have Thermactor ?????
Only the X code
« Reply #4 on: April 05, 2013, 02:02:34 AM »
Only the X code
What about Canadian DSO's? S codes (390-4V) to Canada, generally did not get the Thermactor smog systems in 1968.
« Reply #5 on: April 05, 2013, 02:09:43 AM »
Poster didn't mention export cars and since few questions tend to relate to those few cars I overlooked that possibility. Would have mentioned if any of the MPC's I have listed that difference and  the export parts list doesn't mention a change in the fan clutch. ;)
Good catch
« Last Edit: April 05, 2013, 02:17:27 AM by J_Speegle »
Offline TLea
« Reply #6 on: April 05, 2013, 08:39:55 AM »
The MPC is not really accurate as to what came on assembly line. All 390 non AC cars I have seen came with the C8OE B clutch. C8OE B is also the correct fan blade
Offline 69GTconvert
« Reply #7 on: April 05, 2013, 10:29:36 AM »
Thanks everyone for your feedback. Very helpful as usual. So now I'm on the lookout for a C8OE B clutch and fan. If anyone has these parts or knows of anyone who might, please let me know.
George
Georgia
« Reply #8 on: January 03, 2021, 05:32:36 PM »
In this case, the MPC is accurate - the fan blade "marked C8OE-B" and serviced as C8OZ-8600-A is what is called out for a 390.
However, the blade "marked C8AE-D" (C8AZ-8600-D) is listed for 390 with "extra cooling" "hang-on A/C"
There is nothing listed for a 390 with factory "select-aire" A/C.  Can someone help with that?
« Reply #9 on: January 03, 2021, 05:50:14 PM »
First thanks for bringing this back up to the top. One of the side benefits of asking new questions in an older related thread it appears. Back when this threads was started I don't think I had any build sheets for the 390 4 speed no AC application but currently I do and can confirm that this one had the C8OE-B installed originaly
Can't help with the dealer installed AC question since that would not have been installed at the factory. We would need a number of original cars with the right combination that matched to confirm since I don't think the installation instructions include that information either
As for factory 69 390 with AC I don't currently have a build sheet with that combination. Only thing I can offer is that for 68 both factory AC  and non AC 390 buildsheets show the same C8OE-B
