Author Topic: 68 main dash wiring harness install  (Read 2738 times)
Offline Oz390
« on: March 30, 2013, 01:25:03 AM »
'68 FAM shows a clip on the main harness I don't seem to have on any of my 4 '68's.  Noted in red below , I see no way to wrap the main harness as shown, or a spot to clip as shown...
Just a theoritical idea that never got inplemented or mine have lost them?  If used anyone got a photo, as I can't interpret the pic to see how this would work.  Way hard to twist the main loom ans shown, and no nearby mount that seems likely...??
8R03S : 76A I 2A 15M 72 5 U
Re: 68 main dash wiring harness install
« Reply #1 on: March 30, 2013, 04:15:42 AM »
If you look at the date on that particular page that might explain when it was used (if it was a running change)
Will look through what I've got as far as 68 pictures for an open dash
Offline Oz390
« Reply #2 on: March 30, 2013, 05:17:49 AM »
Actually, I lied.... I went back over the cars photos and parts and did find a long strap that "could" be it.  About 1/2" wide and 6-7" long, folded pretty much in half.  Rubber dipped cover like the J bracket that hold the harness to the dash support behind the cluster.
It connects to the stud at the front of the fresh air vent that is not used by the vent housing.  Odd location as it pulls the whole harness far forward and makes it diffucult to connect the instrument cluster.  It was in a April build 289/C4 Cal Special... nothing like it in any of the big blocks, so not sure if that is relevant, which would not make much sense if it was different for them as the harness and dash are the same...
Offline Oz390
« Reply #3 on: April 01, 2013, 03:17:05 AM »
This is the part...
Not on any of the early cars, so maybe as noted a running change.
Offline TLea
« Reply #4 on: April 01, 2013, 08:56:03 AM »
does the car it came out of have ac?  ;)
Offline Oz390
« Reply #5 on: April 02, 2013, 03:50:52 AM »
Nope. Pretty much a one owner GT/CS that looked pretty stock under the dash.  No AC and none on the Marti.
Offline Oz390
Main dash harness wiring routing, revisited
« Reply #6 on: April 20, 2013, 11:56:56 PM »
ADMIN NOTE: The following two posts were posted in a new thread and then merged with the earlier one to keep information and discussions together.
I posted this a while ago.
http://www.concoursmustang.com/forum/index.php?topic=6196.0
No conclusive answer.
I was going thru the parts from a 68 dearborn car, and found it had the same part under the dash attached to the front stud, unused by the vent assembly "hat".  I did not disassemble that part of the car.
One Dearborn, one San Jose car.  Anyone else found this bracket (which appears to also be the one used to support AC ducts?) in a '68 non-AC car at this location?  Two cars, two plants, seems an odd concidence...
« Last Edit: November 21, 2021, 04:32:54 PM by J_Speegle »
Offline bullitt68
Re: Main dash harness wiring routing, revisited
« Reply #7 on: November 20, 2021, 10:26:45 PM »
I have the same clips and made a bunch of new ones
Mike
