Author Topic: 1966 power top and fog light switch location  (Read 7964 times)
Offline Kooter
« on: March 29, 2013, 07:27:35 PM »
I have a 66 convertible and I am going to add a power top and fog lights. I am having problems finding the location that I need to put the switches. I found a reference for the top switch which mocked up in the pic attached. However I am not sure where the fog li switch goes. Any help would be much appreciated.
Offline Twilight65
  • Gold Level Subscriber
Re: 1966 power top and fog light switch location
« Reply #1 on: March 30, 2013, 12:00:55 AM »
Found this is Mustang Monthly.
On factory GTs, the foglight switch was located on the extreme left side of the instrument panel, near the courtesy-light switch in the door jamb. However, on a non-factory-type installation, the switch can be located anywhere, including underneath the instrument panel.
Offline Kooter
« Reply #2 on: March 30, 2013, 12:11:06 AM »
I did see that write up but since the article didn't have a top switch I didn't know if the switch would move locations. I also found where other vert owners added fog lights they used the d hole already on the bottom of the dash. Just trying to make it look right.
Offline Twilight65
« Reply #3 on: March 30, 2013, 12:44:30 AM »
Here's a pic of an original GT with power top (Dearborn car). As the MM article indicated though,  if dealer installed it could be anywhere. so I think its up to you whether you want it to look factory or dealer. I also included the template from the article for locating te hole.
Dave
Offline Kooter
« Reply #4 on: March 30, 2013, 03:33:28 AM »
That is exactly what I was looking for.  Thank you for the help.
