Author Topic: Distributor Cap  (Read 2625 times)
Offline Twilight65
  • Gold Level Subscriber
Distributor Cap
« on: February 03, 2010, 06:19:03 PM »
I'm looking to get the correct Distributor Cap (7HA 12106) for my May 1966 convertible with 200 CI. What would be correct,  a Fomoco, or an Autolite ?
Dave
« Last Edit: February 03, 2010, 07:54:04 PM by Twilight65 »
Offline Twilight65
Re: Distributor Cap
« Reply #1 on: February 03, 2010, 08:21:36 PM »
Ok looks like I've answered my own question. MCA rule book says FOMOCo or AUTOLITE. Either with #1 or Autolite on cap. The FOMOCO I found has 1 thru 6 on cap. I'm guessing the cap with just the #1 is for a V8.
Dave
Re: Distributor Cap
« Reply #2 on: February 04, 2010, 03:08:52 AM »
Yes the V8 FoMoCo was the one with only the 1 on the top of the cap. If you need a 6 cyl AUTOLITE I should still have a couple of NOS ones if the FoMoCo you found is not nice enough for your use
Offline Twilight65
Re: Distributor Cap
« Reply #3 on: February 04, 2010, 01:46:29 PM »
Hey Jeff,
Thanks for the offer I'll send you a PM.
Dave
Re: Distributor Cap
« Reply #4 on: May 17, 2015, 10:30:31 PM »
     Doing a little research for a 6 cylinder distributor cap and came across this topic.  Interesting that the Autolite and FoMoCo are mentioned and not the Motorcraft.  I have a NOS Motorcraft cap and rotor.  If not ' correct ' for 65-66 what years are the Motorcraft acceptable or correct for ?  Thanks,  Brian
Re: Distributor Cap
« Reply #5 on: May 17, 2015, 10:37:06 PM »
....... If not ' correct ' for 65-66 what years are the Motorcraft acceptable or correct for ?  Thanks,  Brian
72 up
Re: Distributor Cap
« Reply #6 on: May 17, 2015, 10:47:50 PM »
Thank you Jeff.
