Author Topic: Another convertibe fastener question, tack strip to body  (Read 3271 times)
Offline Oz390
« on: March 24, 2013, 04:10:37 AM »
67-68 FAM's call out a forming machine screw w/lead point.  1 1/2" and 2" 1/4-20.  Most of the ones I have seen are a pointed end self tapper, w 7/16" hex head and captive washer.
Running change, FAM is incorrect, or somewhere along the line a lot of PO's got a hold of the same pointy ended screws...???
8R03S : 76A I 2A 15M 72 5 U
Offline Oz390
Re: Another convertibe fastener question, tack strip to body
« Reply #1 on: March 25, 2013, 07:35:15 AM »
No one has restored a convertible?  :o
Offline TLea
« Reply #2 on: March 25, 2013, 08:32:15 AM »
More than I care to remember.
zinc dichromate, 2 lengths (never measured) SEMS head self tapping machine hex. I dont have one in front of me
Offline Oz390
« Reply #3 on: March 27, 2013, 02:24:59 AM »
Similar to these?   7/16" head.  1 1/2" and 2" long.  (two sizes shown as a top owner sent this to me asking which was correct, I have seen mostly ones like on the left, but don't have a large sample)
« Last Edit: March 27, 2013, 02:27:14 AM by Oz390 »
Offline TLea
« Reply #4 on: March 27, 2013, 08:44:03 AM »
Those look like ones put in because originals were stripped (common) Originals are machine thread. I'll see if I can find a couple and post
Offline Oz390
« Reply #5 on: March 27, 2013, 08:57:19 AM »
Ok that clears it up.  I have some AMK that are machine screws and similar to the spec from the FAM and Guide to Ford fasteners...
Thanks!
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« Reply #6 on: March 27, 2013, 04:49:29 PM »
Mine were machine threads and looked great so I had them replated.  The holes in the gutter where they screwed-in were stripped so I installed aluminum Rivnuts with the correct threads and they will never be seen.
66 Metuch Conv
Nightmist, Std Blu Int
Offline TLea
« Reply #7 on: March 27, 2013, 06:48:19 PM »
« Reply #8 on: March 27, 2013, 07:07:42 PM »
What size?
Offline Oz390
« Reply #9 on: March 28, 2013, 12:09:58 AM »
Based on '68 Body FAM reference, Guide to Ford Fasteners notes:
377344  Hex head Conical SEMS, 1/4-20, 3/4"OD, 1 1/2"L
380462  Hex head Conical SEMS, 1/4-20, 3/4"OD, 2"L
Believe both are 7/16" hex head.
Offline TLea
« Reply #10 on: March 28, 2013, 12:34:07 AM »
exactly
« Reply #11 on: March 28, 2013, 12:39:03 AM »
AMK carries 377344-S36 and references 380462-S36 as "similar" (actually says their item for 377344-S36 is similar too). They are used on 64-73 Mustang convertibles so replacements could be a found in a junkyard. If the top was replaced, or repaired, there's no telling what was used.
Offline Oz390
« Reply #12 on: March 28, 2013, 04:30:57 AM »
Looks like they only have the 1 1/2" so for the 2" its "similar", just shorter...
Offline bryancobb
  • 2009 Ridn' Around
« Reply #13 on: March 28, 2013, 07:45:24 AM »
Those are the exact ones mine had.  There was two lengths.  A couple of mine were short that were suppose to be long but I'm sure that was done on the assembly-line, so I put the same ones back.
I ordered the kit from AMK to replace the incorrect lengths but did not use them because they were accurate enough to suit my desires.
They were pretty nice and a fair copy but I just didn't like them.
Here's the rivnuts.  I know, I know...I'm a stickler in one respect and put something totally un original.  We all are guilty I would like to think.??
66 Metuch Conv
