Author Topic: Fuel Line Clamps for 68's  (Read 2481 times)
« on: March 15, 2013, 08:43:54 AM »
Thanks for the correction guys, I should have looked at my own car. Most 68s should have had zinc finish spring clamps right?
Re: Fuel Line Clamps for 68's
« Reply #1 on: March 15, 2013, 01:16:38 PM »
Some had a olive drab.
« Reply #2 on: March 15, 2013, 07:06:41 PM »
Split the topic so others can find the info later ;)
"Most"   think it depends on what plant your asking about and which location. For the sender and fuel pump would agree
Here are three examples of foot/torque box fuel line clamps (what I'm seeing on all - so far) from San Jose through 68
« Last Edit: March 15, 2013, 07:09:18 PM by J_Speegle »
« Reply #3 on: March 16, 2013, 12:13:20 AM »
I thought I had looked at a 67 mid year Dearborn car that used the crimp bands from the fuel tank to the pump and the spring clamps on the fuel line to filter.
I thought the Wittek style were only used in January - April 68 at SanJose? My dads April SJ California Special had the Witteks my July SJ High Country Special had Spring clamps but could no longer tell the finish.
« Reply #4 on: March 16, 2013, 06:16:04 PM »
The samples above are from in that range will check out side that period if you would like?
« Reply #5 on: March 16, 2013, 08:01:01 PM »
Jeff do you have any from the 67 model year, Early 68 and late 68? I am trying to establish when they started and ended using the Wittek clamps.
Thank for taking the time to look. Marty
Offline Dudley
« Reply #6 on: March 17, 2013, 01:25:43 PM »
Marty, from my June SJ '68 build...........the clamps at the floor support have white-out from the flash, they have a gold tint to them.
« Last Edit: March 17, 2013, 01:30:46 PM by Dudley »
« Reply #7 on: March 17, 2013, 06:26:30 PM »
After the change of style to the fuel they used the spring clamps - Picture is from the latest built car of #23057
Most cars I have fit that mid through spring period could not find a single spring clamp in a picture for the mid fuel line clamps. Also included the few Cougars I have from that plant and year but have no idea when they were build but they were the same
Offline TLea
« Reply #8 on: March 18, 2013, 08:01:25 AM »
I have observed #2 Whitek stopped in NJ around March 68. SJ seems a couple months later
« Reply #9 on: March 18, 2013, 09:21:52 AM »
Thank you Jeff for your research. Tim I had all ways thought the Wittek stopped in SJ by the end of April but Dudleys car shows them being used in to June.
Would I be correct in saying the no one has see the Witteks used in the 67 Model year at any plant?
