Author Topic: 69 Dearborn Mach 1 S Code Shocks  (Read 3030 times)
Offline G Wood
« on: March 11, 2013, 01:49:00 PM »
I have read several posts regarding shocks, from what I understand the shocks (front and back ) are semi-gloss black. Are there any other paint markings/daubs or visual indicators applied prior to installation?
Re: 69 Dearborn Mach 1 S Code Shocks
« Reply #1 on: March 11, 2013, 08:00:57 PM »
Correct if we're discussing Mustangs ;)
All were color coded during 69 so that the worker on the line could look at the buildsheet, pick out the correct ones (front or rear installer) and quickly install them.   Met one of the San Jose front stock installers years ago.
Color depended on the markings on the shocks and recorded on buildsheets. Marks were typically a short daub/stripe (1") at the base.
Application of the shocks looks to be dependent on engine, trans, type of suspension and when the car was build.
Anticipating your next question (what would be correct for my car ;)   only have two 69 S code buildsheets for four speeds right now - will check my notes to see if I have something there.
Offline G Wood
« Reply #2 on: March 12, 2013, 02:57:34 PM »
Jeff, thank you for the response and yes you anticipated my next question. Let me know if you are able to find anything.
« Reply #3 on: March 12, 2013, 07:49:05 PM »
So ;) you do have an automatic S code Mach I?
Just confirming
Offline G Wood
« Reply #4 on: March 13, 2013, 09:47:45 AM »
Jeff:
Manual transmission.
Offline PerkinsRestoration
« Reply #5 on: March 13, 2013, 03:28:51 PM »
Rear 1 orange daub, Front 1 white daub. according to 69 build sheet decoder.
« Reply #6 on: March 13, 2013, 11:30:37 PM »
Beat me too it  ;)   Matches the build sheets I've got copies of.
Offline G Wood
« Reply #7 on: March 14, 2013, 11:18:22 AM »
Thank you for your help.
Garth
Offline G Wood
« Reply #8 on: March 14, 2013, 07:13:13 PM »
One last question, were the paint daubs applied near the base of the shock, on the lower tube?
« Reply #9 on: March 14, 2013, 09:26:01 PM »
This help
Offline G Wood
« Reply #10 on: March 14, 2013, 09:31:29 PM »
Yes, this is what I need.
Thank you.
Garth
