Author Topic: Repainting '66 289--Details Needed  (Read 9691 times)
Offline drummingrocks
« on: March 05, 2013, 11:34:29 PM »
I'm redoing some details on my '66 fastback, built December 8th, 1965, at Dearborn.  I have some questions about the engine paint on the 289.  I'm using Bob Mannel's book as a basic reference, but I know lots of details in books like his can vary from what actually happened on the assembly line.
 I think I've got most of the basic details correct, but I'm still concerned about the colors that should be on the attaching hardware; in other words, which items were already installed on the motor when it was painted. Please correct me if I've got any of this wrong.
Items to be painted Ford Blue:
--Oil pan, drain plug, and mounting bolts
--Water pump and mounting bolts
--Exhaust manifolds and mounting bolts (moderate overspray only)
--Intake and manifold bolts
--Thermostat housing and bolts
--Small bypass hose and clamps on the water pump
--Valve covers
--Carburetor spacer
--Air cleaner
Items I have questions about:
1. Should valve cover hardware be painted blue or left natural?  How about the little rubber-coated J-hooks that install under the driver's side valve cover bolts to route the oil sending unit wires--were they painted with the engine or installed later?
2. Was the dipstick tube bolted to the block when the engine was painted?  Should the bolt be painted Ford blue or was it installed later?
3. Should I leave an unpainted ring around the top of the oil dipstick tube, where the paint wouldn't have reached underneath the dipstick itself?
4. Should there be any overspray on the bellhousing?  This is a 4-speed car, if it matters.
5. Should the heater hose elbow that screws into the front of the intake be natural or Ford blue?  Was it on the intake when the motor was painted?
6. This is a factory air car, and as such, has some spacers on the water pump bolts.  Should any of these spacers be Ford blue, or were they natural?
Thanks so much for any help!!
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
Re: Repainting '66 289--Details Needed
« Reply #1 on: March 06, 2013, 11:43:42 AM »
About the best info you can get.  I think all engines left the Cleveland plant already painted?  If yours was pre-JAN 1966, there's no chance it came from Windsor like mine did.
http://www.mustangmonthly.com/featuredvehicles/mump_1003_56_mile_1966_mustang_hardtop/
http://www.mustangmonthly.com/featuredvehicles/mump_1005_1966_ford_mustang_fastback/
66 Metuch Conv
Nightmist, Std Blu Int
« Reply #2 on: March 06, 2013, 12:41:48 PM »
Typical for the 2 middle bolts to be installed, believe the J-hooks would typically not be installed, but would have to confirm
Yes, dipstick tube bolt attached.
That would be fine
No, trans was not installed when engine was painted.  Spacer plate was in place though.
Typical to see these painted block color in '66, but would not say that's an absolute.  Definitely installed prior to painting engine
Spacers would be added later, so no block color on them.
« Reply #3 on: March 06, 2013, 02:14:30 PM »
Thanks Bryan, I remember seeing both of these cars in their respective issues of Mustang Monthly, but never even thought about looking back to these for details.  Regarding the engine, the car was built on December 8th, 1965, so it's not from Windsor.
Charles, thank you for all the help also!
Offline 6S280
« Reply #4 on: March 06, 2013, 02:56:32 PM »
Follow-on question: If the dipstick tube was BOLTED in place then that bolt would be painted blue.  Was that bolt later removed after painting to bolt the coil in place and therefore the bolt holding the dipstick tube and coil in place should be painted blue?
« Last Edit: March 06, 2013, 02:58:03 PM by 6S280 »
« Reply #5 on: March 06, 2013, 03:35:37 PM »
Good question.  Also, was the PCV grommet already installed in the valve covers when they were painted?
« Reply #6 on: March 06, 2013, 03:37:38 PM »
no paint on grommet.
« Reply #7 on: March 13, 2013, 11:01:55 PM »
Just a few last questions.  I've got the engine painted now, all I have left to do is the air cleaner and a few small details.  Does the clip/bracket that attaches to the water pump and holds the fuel line get painted block color?  Also, this is a 4V car.  Does the bracket for the throttle return spring get painted block color, or is it left natural?
Also, what color should the heat shields for the motor mounts be?  They come in stainless steel.  Is this correct?  Here's a link to the shields I'm talking about:
http://www.npdlink.com/store/products/heat_shields_motor_mount_stainless_steel_originals_were_carbon_and_rusted_quickly-105608-0.html
And finally, should the motor mounts be black or natural?
And last but not least, should the underside of the air cleaner lid be natural or painted blue?  And is the inside of the air cleaner housing itself, where the air cleaner element sits, be blue or natural?
Thanks again for all the help!
« Reply #8 on: March 13, 2013, 11:27:32 PM »
Painted with block
Not painted with block
Originally steel - painted a similar color as the engine. Painted different time and location so the tint/shade can vary a little
Got to leave one for the other posters ;)
Bottom exterior of the air cleaner is pained engine color (again shade can vary since it was painted where they were made)
For a 66 I would vote that the interior was blue also
« Reply #9 on: March 13, 2013, 11:30:46 PM »
The base of the fuel line clamp was installed before the engine was painted.  Return spring bracket would be installed after carb installed, no paint.
Quote
Heat shields were natural steel, stainless steel would be incorrect.
Quote
Motor mounts would be natural with a black insulator.
Inside of air cleaner would be natural with a little blue over-spray.
Offline DM_1964
« Reply #10 on: March 15, 2013, 12:17:24 AM »
Can you please post some pics of the finished product?
Regards,
Dom
« Reply #11 on: March 15, 2013, 09:03:30 AM »
Sure, I still need to paint the air cleaner and decide what to do about a carburetor, but I'll be glad to update this with my progress.
On another note, does anyone know what the changeover date was on the exhaust manifold lock tabs?  NPD mentions that the changeover from using tabs to not using them occurred sometime in December '65, which falls right in the middle of when this car was produced.  Before, I hadn't installed the lock tabs, but now I'm wondering if I should have?
« Reply #12 on: March 15, 2013, 10:10:27 AM »
Before, as the engine bay was after restoring the car in 2009, engine was painted with Krylon spray can enamel:
Engine sanded, cleaned, taped off, and ready to be repainted:
Repainted with PPG single stage:
Offline 66RavenGTCoupe
« Reply #13 on: August 14, 2013, 09:36:51 AM »
I don't seem to have these heat shields. Where do they mount exactly? Does anyone have a picture?
Thanks in advance.
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
« Reply #14 on: August 14, 2013, 09:51:35 AM »
the shields go under the motor mounts.
