Author Topic: 69/70 staggered shock reinforcement plate and hole welded closed  (Read 2575 times)
Offline cjmustangman
« on: February 25, 2013, 03:24:26 PM »
When did they apply the reinforcement plate and weld the unused shock hole closed on staggered shock cars ?
I believe they filled the hole on original cars with caulking before the modification was made, is that correct ?
Was this done because of cracking ?
Was it a service modification ?
Was it specific to plants ?
Arild
Re: 69/70 staggered shock reinforcement plate and hole welded closed
« Reply #1 on: February 25, 2013, 09:27:50 PM »
Are you referring to the plug/cover over the unused hole?
Have seen both - My 69 Boss has the cover (looks like the Boss 9 modification) believe it was an early thing dropped later - April build
My Jan 69 San Jose car had no cover - just an open hole
I've never seen that - nor do my staggered shock cars have that (Dearborn and SJ  69's)
Offline hkopp
« Reply #2 on: March 25, 2013, 01:45:26 PM »
Glad to hear that Jeff...my May 21 San Jose 69 mach 1 also has the open hole.  I thought for sure something was lost.  Odd that it is just left open though...
1956 Ford F100
1959 Galaxie
1960 Chevy k10 sb
1965 Mustang 347, 5 spd, 1st car!
1967 Camaro SS350 all #'s
1967 S code
1969 Mach 1 428SCJ-R #'s
1969 Mach 1 428CJ-Q Auto
1969 Mustang Grande, 650hp, 2nd car!
1970 Mustang
1970 Mach 1 351C
1975 Ford F250, 44s, 21" lift, 3rd car!
2002 Avalanche
2011 Vette
« Reply #3 on: March 25, 2013, 03:18:29 PM »
Likely saved Ford a few cents - which adds up over time
Offline elim
« Reply #4 on: March 25, 2013, 05:01:16 PM »
if the hole didn't get blocked,did the other side might not get  the reinforcement
« Reply #5 on: March 25, 2013, 09:26:46 PM »
What plant and/or year?
« Last Edit: March 25, 2013, 09:57:07 PM by J_Speegle »
Offline elim
« Reply #6 on: March 26, 2013, 03:44:02 AM »
Dearborn 70,no month i was just curious as have heard when looking at 4sp cars to look for 2 things the blocked hole and the welded reinforcement.The pic is from the net that i found.
« Reply #7 on: March 26, 2013, 06:14:35 PM »
The picture (if its the same one I have) is of a April 70 Dearborn example. Looking at the pictures I have I found the hole plug and extra supports on 70 NJ and Dearborn examples. Don't have any clear 70 San Jose examples to compare. 69 seems different as I can find examples from Dearborn with and without (all staggered cars) and have not found a 69 San Jose car yet with either.
Just reporting ;)
