Author Topic: Duplicating The Top Concave Edge On a 69-70 Fastback Quarter Panel  (Read 2723 times)
Offline kcodecoupe
Whats the best way to duplicate the top edge of 69-70 fastback dynacorn full quarter panel from flat to concave like an original panel , dolly& hammer or make some sort of jig and press it in ,thanks.
« Last Edit: February 24, 2013, 02:10:10 PM by J_Speegle »
Re: DUPLICATE THE TOP CONCAVE EDGE OF A 69-70 FASTBACK QUARTER PANEL
« Reply #1 on: February 23, 2013, 10:32:13 PM »
     If your looking at the 3-4" wide section below the 1/4 window and sail panel ?   Mine in flat.  Brian
Offline kcodecoupe
« Reply #2 on: February 24, 2013, 06:21:42 AM »
The area i am refering to is on each side of the rear window not the quarter window and is almost the full legnth of the panel to the rear end cap.
Offline dan green
Re: Duplicating The Top Concave Edge On a 69-70 Fastback Quarter Panel
« Reply #3 on: March 07, 2013, 09:54:17 PM »
 Good eye, many others have missed this detail.  I used a short section of an oak dowel and a hammer.
« Last Edit: March 07, 2013, 09:56:31 PM by dan green »
Offline kcodecoupe
« Reply #4 on: March 09, 2013, 11:33:30 AM »
Dan ,nice job. did you do it before the quarters were welded on or after, and what size oak dowl did you use thanks.
« Last Edit: March 09, 2013, 11:35:01 AM by kcodecoupe »
Offline dan green
« Reply #5 on: March 09, 2013, 01:57:37 PM »
I did it after welding the quarter in place.  I remember correctly I used a 3/4 dowel.
Here is a pic before.
Offline craig429
« Reply #6 on: March 10, 2013, 01:19:03 AM »
I am in the same boat with Dynacorn qtrs. I am curious how you used the dowel. Did you have the dowel resting on the area to be indented and hit it with the hammer? Did you have a dolly on the underside when you hit the dowel with the hammer? Did it take much force to form the indent?
Thanks for your help
1969 Mustang Mach1 390
Offline dan green
« Reply #7 on: March 10, 2013, 11:23:40 AM »
I was very pleased with the fit on the quarters, i think the detail along the back glass was the only problem.
Both sides of the small flat area are very rigid, I didn't feel I needed to support the back side with a dolly and once the panel is welded in it is difficult to get to the area behind.  The dolly would also have to be shaped to accept the cove, plus the cove is wider the closer you get to the quarter extension.
I sanded the ends of the dowel round also to prevent any sharp edges from denting the quarter in a line or crease perpendicular to the cove.
It was actually very easy to form the cove which is very slight, you don't have to hit very hard.
Offline craig429
« Reply #8 on: March 10, 2013, 01:11:24 PM »
Thank you very much for you explanation. I purchased my project 70 Mach1 with the quarters already replaced, but noticed the non correct detail and wasn't sure how I was going to fix it. You have given me the method. Thank you
