Author Topic: 64 1/2 260 Distributor Resto Help Needed  (Read 2246 times)
Offline must69
« on: February 19, 2013, 05:24:56 PM »
I am restoring the distributor in my July mid July 1964 built 260 Automatic Coupe.  The distributor has the lubrication cap going into the side of the shaft.  Is there some sort of material inside this shaft that is designed to prevent oil from leaking out of this tube? The tube seems to be blocked and before I remove the material I am curious if something is supposed to be there.
Secondly, the original Vacuum diaphragm has a tear in it.  The diaphragm is not serviceable and the aftermarket part looks nothing like the original equipment part.  Anyone have any suggestions?
Thanks Phil
Re: 64 1/2 260 Distributor Resto Help Needed
« Reply #1 on: February 19, 2013, 05:35:33 PM »
you need to contact tim o'connor. tim@428cobrajetcars.com he does a great job rebuilding distributors.
Offline must69
« Reply #2 on: February 20, 2013, 01:09:49 PM »
Thanks for the tip!
Phil
« Reply #3 on: February 20, 2013, 01:12:13 PM »
tim's website   http://428cobrajetcars.com/
Offline kutzoh
  • Gold Level Subscriber
« Reply #4 on: February 20, 2013, 03:13:25 PM »
Phil-
   Tim O'Conner did a rebuild / restore on my distributor for my '64.5 D-Code, Tim does top notch work.
Greg
Offline app01
« Reply #5 on: February 20, 2013, 03:34:35 PM »
Tim also did my 70 B2 one and it looks perfect and works great.
Currently own:
1962 Corvette 340hp
Previously Owned:
1970 Mach 1 (my 2nd car)
1989 GT
MCA #62598
www.PalmieriConcepts.com
Offline C5ZZKGT
« Reply #6 on: February 20, 2013, 06:31:53 PM »
 Anyone know what ever hapened to Distributor Dynamics?? I've forgotten the guys name there.....sure did a good job on my '65 Hipo distributor.
« Reply #7 on: February 20, 2013, 10:52:51 PM »
Didn't know anything "happened" to him- (Chuck Barbaro) I've not had any reason to contact him since the last one he did for me. Couple hours driver so hes sort of local
« Reply #8 on: February 21, 2013, 12:29:33 AM »
I got two C5GF-12127-A distributors rebuilt by him last year and he indicated at that time he was tapering off due to a couple of items, age and parts availability. He does (or did) and excellent job.
Offline fast66
« Reply #9 on: February 21, 2013, 05:51:10 AM »
How about Pete at Orlando Mustang... he did an excellent job for me restoring my distributor.
http://orlandomustang.com/aboutus.htm
br
Claes
6T09K212784
63A 4 25 21B 951384 5 6
