Author Topic: Shelby 289 Hipo oil Pan  (Read 4135 times)
Offline ceswert
  • Silver Level Subscriber
« on: February 14, 2013, 09:17:22 PM »
Did Shelby use the blue oil pan that came on Hipos or did they change to the aluminum Cobra pans?
67' Shelby GT 350 nm blue/4sp/#0089
07' Shelby Super Snake 725hp/white/#0073
71' Mach 1 429cj grabber blue/4 sp./ac
Re: Shelby 289 Hipo oil Pan
« Reply #1 on: February 15, 2013, 12:34:01 AM »
What year?
« Reply #2 on: February 15, 2013, 01:18:32 AM »
They started out (different year than your car) and then changed to the standard Mustang oil pan starting in 67.
Nothing special about a K code or Shelby 289 oil pan for a 67 that I know. So other than a nice clean steel pan will serve your need ;)
Offline ceswert
« Reply #3 on: February 15, 2013, 05:25:07 PM »
OK, thanks!
Offline Andrew@MagMustangs
    • MagMustangs
« Reply #4 on: February 16, 2013, 06:57:31 PM »
I have heard that early 67 GT-350 still used the COBRA oil pan. Is there any truth to that?
« Reply #5 on: February 16, 2013, 07:49:25 PM »
Popular addition to a 67 350 sure some buyers were not happy that that was dropped from the changes to the engines as it was in 65-66. Don't recall hearing that story over  the years nor did I find it listed in the recently published registry for 67's in the running changes
Offline ceswert
« Reply #6 on: February 17, 2013, 11:46:22 AM »
So these pans were purchased over the counter from 65-66 stock? Were they aftermarket parts too?
« Reply #7 on: February 17, 2013, 05:59:52 PM »
Yes Ford (parts counters) and generic part stores could order and sell the aluminum pans to anyone that wanted to buy one - into the early 70's possibly. And then the reproduction ones (many made) followed that.
Here is a scan of the Ford Performance accessory catalog for one year. picture shows another oil pn (not the Msutang version but you get the idea.
« Reply #8 on: February 23, 2013, 06:53:39 PM »
The early 67 gt350's did not use the cobra oil pan because of clearance issues with the powesteering brackets etc. There was a cobra oil pan on #0001 when I bought it with some modified P/S hose brackets . I kept it on it because it may have been something that was tried and didn't work .  I traced back as far as 1971 which may or may not have been original because it was already old by then. In 1989 when I bought it I decided to error on the side of caution when i restored it. In the years to follow I have not found  documentation one way or the other to substantiate the Cobra oil pan on #0001. I have owned a number of single and double digit 67's and examined many more none had a Cobra pan .
« Last Edit: February 23, 2013, 07:00:44 PM by Bob Gaines »
