Author Topic: Dist-O-Vac  (Read 12299 times)
Offline Anghelrestorations
    • Anghel Restorations
Re: Dist-O-Vac
« Reply #15 on: February 19, 2013, 02:38:10 AM »
Yes, the one I posted is indeed from a 302 car.
Marcus Anghel
www.anghelrestorations.com
Offline 70Mach
Re: Dist-O-Vac
« Reply #16 on: February 19, 2013, 10:34:34 AM »
Thanks for the close up pic.  I was wondering about the black box w/ black lid that was mentioned earlier.  I think the color of the lid determines which type of wiring connectors were used and which vehicles it was to be used on.  From one of the dist-0-vac service manuals, Mustangs had 2 boxes available both with blue lids.  And they are the only ones that used blue lids.  In your pics the black box/blue lid 'S' is for the Mustang 351C 4V, the white box/blue lid 'V' is for Mustang 302 2V.  And the white box/black lid 'U' is Fairlane, Montego, Ranchero 302 2V.  The book never mentions 351W but may maybe the 302 ones were used for those too, I don't know.
« Last Edit: February 19, 2013, 10:40:36 AM by 70Mach »
'70 Mach 1, Metuchen, 351C, 4 bbl, auto, a/c, PDB, PS, shaker, white stripe, Dark Ivy Green w/black int.  '67 Mustang, San Jose, convertible 390, 4 speed, console, rear grill, Nightmist blue, standard blue interior
Offline 70Mach
Re: Dist-O-Vac
« Reply #17 on: March 21, 2013, 10:11:08 AM »
Any idea where I might be able to find/buy the vacuum tubes?
Offline 70Mach
Re: Dist-O-Vac
« Reply #18 on: April 11, 2013, 12:51:07 PM »
Finally located a set of lines!
Re: Dist-O-Vac
« Reply #19 on: April 11, 2013, 04:54:53 PM »
Congrads... were they the same as the ones I posted or different ?
Offline 70Mach
Re: Dist-O-Vac
« Reply #20 on: April 11, 2013, 08:03:43 PM »
They're almost the same.  The thicker of the two lines on the set I got is completely straight instead of having a bend like your pictures show.  They look more like the Ford diagram page that you posted that shows the different setups for 351C 4V shaker w & w/o a/c  They look like the ones for w/o a/c.  The diagram for the one w/ a/c isn't as clear so it's hard to tell what that one is really like, although it does look to be fairly straight too.  I'm hoping since our car has a/c that there is no difference.  Any idea?  I know the 302 tubes look completely different from what I have seen for sale on ebay.
The set I got was missing one of the mounting tabs so I had to make a new one.  And one tube was disconnected from the other tab so I had to tack that back on.
I found them by emailing anyone that had Dist-O-Vac parts, or other parts they specifically said came off of a 1970 351C FMX Mustang, for sale on ebay and asking if they had other parts.  Around the 18th inquiry is when I finally hit pay dirt!
Offline hkopp
Re: Dist-O-Vac
« Reply #21 on: April 12, 2013, 12:18:39 AM »
Anyone have a need for the speedo unit and (if I can find it) the short cable?  I've had one for a while and have no use for it...gotta pay for the ride tho.
1956 Ford F100
1959 Galaxie
1960 Chevy k10 sb
1965 Mustang 347, 5 spd, 1st car!
1967 Camaro SS350 all #'s
1967 S code
1969 Mach 1 428SCJ-R #'s
1969 Mach 1 428CJ-Q Auto
1969 Mustang Grande, 650hp, 2nd car!
1970 Mustang
1970 Mach 1 351C
1975 Ford F250, 44s, 21" lift, 3rd car!
2002 Avalanche
2011 Vette
Re: Dist-O-Vac
« Reply #22 on: January 13, 2021, 09:56:03 PM »
Black on black unit from a 70 Cyclone GT 351-4V auto A/C car, located above glove box, which would be D0AZ-9E718-C according to the MPC.  The cover does not have the suffix, only the "D0AF-9E718- " text string.
I've included Mercury and Ford MPC info as well.
Mercury used D0AZ-9E718-A, B, C, G, H and D1AZ-9E718-A on their car lines
Ford used D0AZ-9E718-A, B, C, G, H, and J.
Total number of variations = 7
Perhaps body and cap color combination was used to identify the application?
