Author Topic: what goes here?  (Read 6155 times)
Offline TLea
what goes here?
« on: February 13, 2013, 09:39:02 PM »
69 Dearborn vert. There are 2 holes that are located between the door jam switches, one square, one round about 1/4". The square one if for a locator tab on the back of the weatherstrip and is not used on vert A pillar weather strips. The round hole has a corresponding hole in the weatherstrip but not metal backed like the ones the screws go in. What goes in it? I'm thinking plastic push pin?
Offline Anghelrestorations
    • Anghel Restorations
Re: what goes here?
« Reply #1 on: February 14, 2013, 12:59:02 AM »
Tim...you need to repost that picture...its not coming thru clear.
Marcus Anghel
www.anghelrestorations.com
Offline TLea
Re: what goes here?
« Reply #2 on: February 14, 2013, 10:44:11 AM »
Hmmm Its clear on mine, could it be your browser?
Offline app01
Re: what goes here?
« Reply #3 on: February 14, 2013, 10:46:43 AM »
I can also see that pic fine.
Currently own:
1962 Corvette 340hp
Previously Owned:
1970 Mach 1 (my 2nd car)
1989 GT
MCA #62598
www.PalmieriConcepts.com
Re: what goes here?
« Reply #4 on: February 14, 2013, 06:40:40 PM »
Ok...computer problems fixed now.  Attaching some pictures here that show the two holes.  One of them is used as a locating tab for the stainless trim and the other is not used at all.  Pictures show it from the back installed and from the side and front so you can see.  I have several cars that are the same way.  You can also see whats left of the original material used between the body and the stainless....similiar to the brake booster gasket material.
Marcus Anghel
Offline TLea
Re: what goes here?
« Reply #5 on: February 15, 2013, 07:26:12 AM »
Thanks Marcus, that is perfect. Safe to assume thats a coupe?
Re: what goes here?
« Reply #6 on: February 15, 2013, 08:58:28 PM »
Yep...its a coupe.
Marcus Anghel
Offline TLea
Re: what goes here?
« Reply #7 on: February 15, 2013, 09:34:37 PM »
Yep...its a coupe.
Coupe and fastback have the metal channel there that hold the weatherstrip, vert does not. I'm still checking but I think the vert gets a plastic pin that goes through weatherstrip into the round hole
Offline 69RavenConv
  • Owner since '74
Re: what goes here?
« Reply #8 on: February 16, 2013, 10:19:51 PM »
Quote
I believe you're correct, I used the pin there in my own vert. Without one, there is nothing securing that section of weatherstrip but glue, which would quickly fail with repeated door openings. I, too, would like to see a definitive answer, but I think you're right.
Phil
'69 Convertible - Dearborn June 4, 1969 - Raven Black & Red - 302-2V
Offline TLea
Re: what goes here?
« Reply #9 on: February 18, 2013, 11:06:15 PM »
Found the answer per Ford assembly drawing. Takes pin 382570 S      1/4" hole, 1/2" head, 1/4" mat thickness. The entire weather strip gets backed with foam tape .12 thick x .88 wide. Probably the same as what Marcus showed on coupe weatherstrip retainer. The pin is vert only. AMK sells it in a 10 pack under B 10764.
Clip is also used by GM as a seal retainer
Offline TLea
Re: what goes here?
« Reply #10 on: February 18, 2013, 11:06:59 PM »
Anybody have a source for the .12 x .88 foam tape?
Offline rayms69
Re: what goes here?
« Reply #11 on: February 19, 2013, 03:42:35 PM »
I asked about that foam tape a long time ago, 3M double sided tape was the concensus. I would prefer something closer to original myself. I was thinking a little seam sealer apllied to remaining foam tape on the weatherstrip to seal it up. When i removed mine most stayed with the stainless, but i would rather start with clean stainless and fresh tape, but....
10-26-1969 Dearborn 428 SCJ auto
Offline TLea
Re: what goes here?
« Reply #12 on: February 19, 2013, 10:19:10 PM »
Do we know that the foam tape is double sided sticky? Its different than the double sided used to hold roof rail moldings
Re: what goes here?
« Reply #13 on: February 19, 2013, 10:26:54 PM »
Feels and looks that way after 45 years. Day one?  can't be sure. There might be a note in the assembly manual
Offline rayms69
Re: what goes here?
« Reply #14 on: February 19, 2013, 11:40:30 PM »
i just looked at my removed roof rail weatherstriping stainless, the backside(to the car) has the foam tape. When i took it off, very little needed to be cleaned off the car, 95% was still on the stainless. Thats why i was just going to clean the edges a little neater than factory and use some eastwood seam sealer when i put it back on. It looks like most of the glue( which there wasnt much used) pulled off with the weatherstripping when i pulled it out of the channel of the stainless. This was original stuff, i was the first to touch it. Dearborn 10-20-69. The glue in the channel is more black in appearance. As opposed to the yellowish glue on the door weatherstrip. I still havent done the drivers side which i was gonna do in the spring. I will take a closer look at the drivers side Friday when im off for the weekend. it again hasnt been touched since the factory did it when it was born, just to reassure myself. Dont remember any double sided tape though in between weatherstrip and stainless.
