Author Topic: AC compressor support tube  (Read 1320 times)
Offline saa
« on: February 13, 2013, 03:24:34 PM »
Hi,
From what I have understood there’s a difference in the shape of the AC compressor support tube on a 1965 and 1966. Is this correct? And if this is the case, what are the differences?
BR//SAA
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
Re: AC compressor support tube
« Reply #1 on: February 14, 2013, 12:45:20 PM »
It has to do with whether or not your driver's side valve cover has a oil filler pipe/hole or not.  The later (66 style) had a zig-zag to clear it.
Cars that had the oil fill pipe into the timing chain cover didn't need the zig-zag.
66 Metuch Conv
Nightmist, Std Blu Int
« Reply #2 on: February 14, 2013, 01:50:58 PM »
If I remember right, the difference has to do with Ford going to the tall valve-covers in late '66.
Offline bryancobb
  • 2009 Ridn' Around
« Reply #3 on: February 14, 2013, 10:10:56 PM »
Picture C should clear it up.  My March 66 Metuchen C-Code with a Change Level 11 Windsor engine has the bottom type that passes on the OUTSIDE of the oil fill cap.
66 Metuch Conv
