Author Topic: 90 deg. elbow tube on 6 cylinder with a/c  (Read 1301 times)
Offline tnguy624
« on: February 13, 2013, 09:26:29 AM »
I am trying to find what ford calls an (elbow tube to engine 90 deg. 5/8") The numbers I found for it are 376464-S (11-156A)
On the 6 cylinders with a/c the tube screws into a 90 deg fitting which screws into the side of block near the water pump. A piece of heater hose connects this tube to the fitting on the part that the carb bolts on to.. On non a/c cars there is just a straight piece of steel tube. But I guess this system is used to go around the a/c compressor.
I have the original tube and the 90 deg fitting, but in the past someone cut it off right at the bend. The car is a dearborn convertible, with a scheduled build date of Nov. 17, 65. Any and all help or advice is greatly appreciated, and let me thank anyone who can help in advance.
Terry
1966 Convertible
Born Jan. 17, 1966 Dearborn
Rebirth began Feb. 2012
Reborn July 2013
1966 Sprint
Born  May 27, 1966  Dearborn
D-4 Interior: Parchment/Emberglo
V    Exterior: Emberglo
Rebirth began March 2009
Reborn May 2011
Moved to Australia Dec. 2011
MCA # 78931
Offline koski19
Re: 90 deg. elbow tube on 6 cylinder with a/c
« Reply #1 on: July 26, 2013, 05:29:20 PM »
I just bought one today at Mustang Unlimited
www.mustangsunlimited.com
Part #28599B.......$24.95
Check it out to see if is what you need.
Jeff
Offline C5ZZ
« Reply #2 on: July 26, 2013, 09:19:31 PM »
Jeff
That's not it.
The correct one has a curved bend to it and is a tube.
That's a tough one to find, I have one on mine,
Here are a few pictures of it.
MCA # 00945
Rangoon Red/Red Interior
Offline suskeenwiske
  • 214-347-3628
« Reply #3 on: October 09, 2013, 01:24:46 AM »
Check with CTC Auto Ranch in Denton Texas; I purchased both fittings from them for $35.00. I was there in April 2012 and saw several vehicles, Mustang's, Falcon's and other Ford's that had these still attached to their engines. If you live anywhere near North Texas, drop in on them. Don't bring any tools...just point at what you need and they will pull it. If you don't live near by, they will ship, just tell them what you need. The attached photo is of my engine; the 2 fittings are what I found at CTC.
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
