Author Topic: Battery OK Tag Info  (Read 1300 times)
Offline calypso
Battery OK Tag Info
« on: February 11, 2013, 06:03:17 PM »
Is "Charge Reading" the voltage or the specific gravity?  What would a typical "Badge" number be?  Would it be stamped or written?  Dearborn July 1970 car.  Thanks
Re: Battery OK Tag Info
« Reply #1 on: February 11, 2013, 08:10:40 PM »
Taking what we've seen on 69 Dearborn cars and applying it to 70  (since I know of no original 70 ones to use as an example ) I found offer the following
Specific gravity
Stamped number in a circle identified a specific inspector. Seen black in used
Date - rotating stamp with Month and day only
Sticker - Black ink with lines that meet/touch each other
ECS's reproduction should work well for you unless your looking for a paper based sticker that will waste away after a short period
Offline calypso
« Reply #2 on: February 12, 2013, 11:56:16 AM »
Thanks, Jeff
