Author Topic: 64.5 water pump date code and timing cover  (Read 2014 times)
Offline CW4macret
« on: February 10, 2013, 03:42:54 AM »
OK guys two questions.
1. What would be the correct date casting number on the water pump for a April 64 built D code (289 V4)
2. The car came with a couple of extra timing chain covers. Some have the oil filler tube and some do not. I know about the ribs but not sure if a early 289 had the oil filler tube in the timing cover or valve cover or both???
Mac
Mac
64.5, 5F07D
66 Convertible 6T08T
71 Mach1 429CJ 1F05J
01 Coupe
05 GT
08 GT500
14 GT500
Offline ChrisV289
Re: 64.5 water pump date code and timing cover
« Reply #1 on: February 10, 2013, 09:59:26 AM »
Mac,
I believe the casting number on the water pump should be C40E-8505-A.  Date code I would assume would be April 64.  Should have a 64 in a circle with 4 little dots in it.  I assume it could have 3 dots as well for March but I don't know how early they started producing parts.  Maybe someone would know what the earliest date code would be.
2009 V6 Mustang Coupe
Offline $64stang
« Reply #2 on: February 10, 2013, 10:50:24 AM »
Timing chain covers with the oil fill tube, go with the closed valve covers, and the intake with the down draft tube, behind the carb, the no PVC type system.
Offline john_simms
« Reply #3 on: February 11, 2013, 08:39:51 AM »
Not necessarily.  I too have an April built 64.5 with the D-code 289 and my oil fill is on the valve cover with NO down draft tube.  Bob Mannel's book on small block Ford engines does a great job of detailing how the engines were configured with which parts.  I would recommend purchasing a copy of his book.
http://www.amazon.com/Mustang-Ford-Small-Block-1962-1969/dp/B003SFV9JU
Edwardsville, IL
« Reply #4 on: February 11, 2013, 08:44:42 AM »
+1, this is a must-have reference for Ford small block engines.
Offline CW4macret
« Reply #5 on: February 11, 2013, 04:54:58 PM »
Thanks everyone. I have ordered the book.
Mac
Mac
64.5, 5F07D
01 Coupe
05 GT
08 GT500
14 GT500
