Author Topic: 1966 Single Exhaust clamps?  (Read 3978 times)
Offline AU SNK
« on: February 05, 2013, 02:59:58 PM »
Was told back in the Spring the exhaust clamps were wrong on our 66. Does anyone have a picture of what the correct clamps look like?
Unrestored 66 Metuchen, NJ Fastback 6T09C2435XX
Sauterne Gold Metallic, Lt. Ivy Gold Crinkle Vinyl and White Crinkle Vinyl, Pony Interior
Re: 1966 Single Exhaust clamps?
« Reply #1 on: February 05, 2013, 05:32:38 PM »
Which clamp? There are two, the actual pipe to muffler clamp, and the pipe hanger. And just for drill, what engine, plant and month might be useful.
Offline Brian Conway
« Reply #2 on: February 05, 2013, 05:52:50 PM »
Some pictures of the OE single exhaust hanger and clamps from 6R07C automatic.  July 12.  Brian
5RO9A GT  4 Spd Built 5/29/65
9TO2R SCJ 4 Spd Built 9/19/68
Owner Driver Mechanic
San Diego, Ca.
Offline AU SNK
« Reply #3 on: February 06, 2013, 09:32:53 AM »
Its a April 66 M NJ car and looking for the pipe clamps. Like in the center of Brian's pic. Mine does not look like that.
Offline C5ZZKGT
  • Gold Level Subscriber
« Reply #4 on: February 06, 2013, 07:04:22 PM »
Brian, To the best of my Knoledge the larger bracket-looking things on the left side of your picture are TIE-DOWN plates/brackets-(the ones that the original sticker placed where the license plate goes says to remove)
It would be interesting (again) to re-visit the Tie-Down brackets as was done a couple of years ago either here or one of the other sites......
I don't think the ones you are showing are reproduced....
Can you please get and post some better pictures of just those brackets?
I think back in the day alot of exhaust shops cobbled aftermarket hangers TO these tie-down brackets...which made some feel that they were actually part of the exhaust brackets when in fact they were not.
« Last Edit: February 06, 2013, 07:07:00 PM by C5ZZKGT »
« Reply #5 on: February 06, 2013, 08:35:41 PM »
The pipe clamp should look like the left hand middle item in the first picture. It's best described as a long 5/16 inch diameter rod threaded at both ends to 5-16-18 and bent into a "U" with a formed base retainer and two flange type retaining nuts. The pipe strap is a metal strip bent around to almost form a circle held together with either a large 5/16-9X1 1/2 hex head sheet metal screw or a 5/16-18X1 1/2 hex machine screw and nut. There are other types from other exhaust systems (dual) and other years that sometimes get into the mix.
Offline AU SNK
« Reply #6 on: February 07, 2013, 09:44:31 AM »
Is the clamp that holds the tail pipe to the muffler the same?
Now to track them down.
Offline C5ZZKGT
« Reply #7 on: February 07, 2013, 11:02:53 AM »
I don't think the correct clamps and hangers will be hard to find in reproduction though I don't have much knoledge on single exhaust cars.....
I was able to get very correct parts for my '65 dual exhaust K car.....
Offline AU SNK
« Reply #8 on: February 07, 2013, 11:07:57 AM »
My car is un-restored so want to put either good shaped originals or NOS. I see Virginia Mustang has these, guess that could be last resort -
http://www.virginiaclassicmustang.com/65-67-CORRECT-FOMOCO-STAMPED-2-INCH-EXHAUST-CLAMP-EACH-P1792C1071.aspx
« Reply #9 on: February 07, 2013, 12:23:07 PM »
Not to start a parts war, NPD (2013 catalog pg 147) indicates that the style shown is for a "late" 66. It is similar to what NPD states as "early" (and before) 66 that has a lower shoulder on the stamped bar. NPD also states that the nuts were cad plated. I'll let others confirm, dispute or deny any of this.
Offline AU SNK
« Reply #10 on: February 07, 2013, 12:37:02 PM »
what is the NPD part number? I don't have a catalog handy
« Reply #11 on: February 07, 2013, 03:59:22 PM »
From NPD 2013 pg 147:
5A231-16C - short shoulder, 63 - 66 early, $14.95
5A231-16D - long shoulder, 66 late - 68, $10.75
5A231-16E - different finish, 68 - on, $10.75
Offline AU SNK
« Reply #12 on: February 07, 2013, 04:13:15 PM »
Would an April build date be considered late?
Offline C5ZZKGT
« Reply #13 on: February 07, 2013, 09:37:17 PM »
Don't under estimate the quality of ALL reproduction parts, ALL reproduction parts aren't the same, Both NPD and VA Mustang both have very caring, passionate owners and give top quality customer service to boot.
Offline AU SNK
« Reply #14 on: February 08, 2013, 10:25:10 AM »
I have bought from both in the past for a coupe I had, I agree they have great products and those are the only 2 shops I buy from. (bought a new car cover for the 66 this week from VA mustang).
Since I show my 66 in the MCA unrestored class I was under the impression repro parts are not acceptable thus the reason for wanting to find good used parts or NOS.
