Author Topic: 66 SJ front coil spring covers  (Read 2102 times)
Offline MyRed66GT
« on: January 30, 2010, 10:13:13 AM »
The detailing book I have lists these as being flat black-is this correct? Car is 66 built in SJ.
« Last Edit: February 21, 2021, 04:02:08 PM by J_Speegle »
Re: front coil spring covers
« Reply #1 on: January 30, 2010, 12:18:03 PM »
Usually semi-gloss black.
Offline MyRed66GT
« Reply #2 on: January 30, 2010, 03:15:11 PM »
That's what I thought too...Thanks! ;D
Offline bburns31
« Reply #3 on: February 20, 2021, 07:55:02 PM »
I'm replacing my springs and wanted to go ahead and restore the covers. The outside of the cover has a texture. Is this sound deadening or years of build up? I'm considering stripping these down and repainting the semi gloss black. Also how best to restore the nuts and bolts? I can clean them up with a wire brush but are these left raw or sealed or painted?
« Last Edit: February 20, 2021, 07:57:05 PM by bburns31 »
66 Mustang Dearborn C Code Sauterne Gold Metallic
« Reply #4 on: February 20, 2021, 08:31:36 PM »
It looks like factory sound deadener.  The fasteners for the coil spring covers should be phoshpate/oil finish.  The fasteners at the top of the image are for the shocks and shock tower caps and were a different finish (zinc).
Re: 66 SJ front coil spring covers
« Reply #5 on: February 21, 2021, 04:03:27 PM »
Agree looks like the worker sprayed lower than usual and overlapped on the spring covers in your example or could have been an aftermarket undercoating job. Type of material and coverage will generally help you determine between one and or the other
