Author Topic: 64 1/2 Scissor Jack and Ratchet  (Read 5765 times)
Offline DM_1964
« on: February 01, 2013, 01:39:22 AM »
Does anyone have a pic of an exact 64 1/2 jack and accessories?
is there any differences between the 64/65, were they date coded etc?
Regards,
Dom
Offline Anghelrestorations
    • Anghel Restorations
Re: 64 1/2 Scissor Jack and Ratchet
« Reply #1 on: February 01, 2013, 01:59:40 AM »
The scissor jacks were not date coded before Jan 1967.  And yes the early jacks are different.  If you have pictures you can post here can tell you if what you have is correct.
Marcus Anghel
www.anghelrestorations.com
Offline DM_1964
« Reply #2 on: February 01, 2013, 02:13:05 AM »
Thanks for the feedback Marcus,  currently I don't have a jack, hence my post, so I know exactly what I need to source...
Dom
Regards,
Dom
« Reply #3 on: February 01, 2013, 02:27:13 AM »
This is correct for an early car:
Marcus Anghel
Offline 65fastbk
« Reply #4 on: February 01, 2013, 11:48:37 AM »
Would this jack be correct for a SJ May 15 built 65 mustang?
Offline kutzoh
  • Gold Level Subscriber
« Reply #5 on: February 01, 2013, 12:57:45 PM »
Don't believe so, from what I understand there are 2 main features that separate the early ('64.5'ish) jacks from the '65's: the threads and bearing. Early versions had corse threads, '65's had fine threads and the early version had a bearing next to the drive nut whereas the '65's used washers.
Jacks are a gray area due to multiple suppliers and the inability to verify if an "original" jack is still in the car after 40+ years.
Greg
« Reply #6 on: February 01, 2013, 01:15:39 PM »
     This is the jack that resides in my trunk and I don't really know how long it has been there.  Fine thread with a horse shoe type end.  On the drive nut end is a raised casting ' 5150 ' ?   The lug wrench is a Ford service part.  D4ZZ?-17032
Offline 65fastbk
« Reply #7 on: February 01, 2013, 01:44:27 PM »
Greg
Hi Does anyone have a mid year 65 jack that can post some pics:)
Offline 65fastbk
« Reply #8 on: February 01, 2013, 06:59:58 PM »
Hi,
Here is a pic of jacks drive nut, is this a 64.5?
« Reply #9 on: February 01, 2013, 08:26:39 PM »
Don't believe so, ...............
+1
Offline Skyway65
« Reply #10 on: February 01, 2013, 08:47:52 PM »
Here's an original January '65 Dearborn jack.
Gary Schweitzer
MCA #00181
Traverse City, MI
« Reply #11 on: February 02, 2013, 03:22:15 AM »
The only thing I would add to this discussion is that the coarse thread has nothing to do with an early or late jack or an San Jose, Dearborn or Metuchen built Mustang.  This was one supplier that was supplying the coarse thread jack version thru the years.  All coarse thread jacks will be marked with an A to identify this manufacturer as Ausco.
Marcus Anghel
Offline 66RavenGTCoupe
« Reply #12 on: April 05, 2013, 08:53:39 AM »
I have a very original early Dec 65 Build Metuchen 66 GT and this is my jack and ratchet. Can anyone tell me if they are correct? I actually have the original unused spare on original wheel rim with white stampings on the tread face so I'm hoping that these are original too.....
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
Offline outlawincorporated
  • Kangaroo Herder
« Reply #13 on: April 05, 2013, 10:32:16 AM »
66RavenGTcoupe aka daniel.
the example you have provide is constant with what i have found on my NJ cars as well for your time period.
regards.
PHILL BERESFORD.
MELBOURNE.
AUSTRALIA
« Reply #14 on: April 05, 2013, 07:21:47 PM »
Hey Phill,
Thanks for responding. That is good to know as I was starting to wonder about the ratchet mainly. Hope to see you around one day as I'm a Melbourne boy too. Thanks again.
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
