Author Topic: 89 headlight adjustment  (Read 3335 times)
Offline C5ZZ
« on: January 29, 2010, 11:02:47 PM »
Having trouble trying to adjust the headlights on
my sons 89 LX 5.0. I know there are three adjustment
points but any tips on how to do it would be appreciated!
MCA # 00945
Rangoon Red/Red Interior
Offline cobrajetchris
Re: 89 headlight adjustment
« Reply #1 on: January 30, 2010, 12:06:13 AM »
I believe on most of the late model encapsulated headlamps the adjusting screws are a reverse TORX style however a 6 or 7mm socket usually works if you don't have a reverse TORX bit. Have the car on a flat surface about 20 ft. from a wall or garage door and watch the change vertically or horizontally until you get it were you want it, hopes this helps....PS.  normally there is only 2 adjusting screws on a headlamp.
CHRIS KNOBBE
Offline Coupey
« Reply #2 on: February 03, 2010, 05:08:17 PM »
Like was said above two screws.One for up and down the other for left and right.
