Author Topic: 69 Drum Brake Line Mounting  (Read 1720 times)
Offline G Wood
« on: January 24, 2013, 02:28:43 PM »
Can anyone share photos of the metal brake line/clamp location running across the firewall and then the driver and passenger side line/clamp location (in fenderwell area) along the frame rail.
Thanks in advance.
Offline rockhouse66
Re: 69 Drum Brake Line Mounting
« Reply #1 on: January 24, 2013, 05:38:00 PM »
I only have this poor quality low resolution picture of the partial firewall area.  Hope it helps a little and maybe someone else can provide the rest of what you need.
'66 GT FB
« Reply #2 on: January 24, 2013, 08:17:54 PM »
Offline G Wood
« Reply #3 on: January 25, 2013, 09:03:19 PM »
Perfect, thanks gentlemen.
Offline G Wood
« Reply #4 on: January 28, 2013, 02:02:17 PM »
One more favor, does anyone have a picture of the rear brake line and it's mounting position on the firewall (after it comes up from the trans tunnel). My reference book is not clear if the line is mounted to the firewall in this area or not. I need clarification if there is a mounting clip for the line between the distribution block and the first mount position in the trans tunnel.
Thanks again.
« Reply #5 on: January 28, 2013, 05:57:27 PM »
Hopes this helps
Offline Aussiemach
  • Silver Level Subscriber
« Reply #6 on: January 28, 2013, 06:21:47 PM »
1969 Mach 1 351w FMX Built in San Jose, February 26 1969
Offline G Wood
« Reply #7 on: January 29, 2013, 11:19:47 PM »
Thanks for the quick responses, these are what I needed.
