Author Topic: 1967 GT500 Pulleys  (Read 3155 times)
Offline sfm6s197
1967 GT500 Pulleys
« on: January 27, 2010, 09:32:58 PM »
Does anyone have the ability to look up part numbers. I need to find out the engineering numbers for the pulleys for a 67 gt500 equipped with p/s and thermactor.
« Last Edit: January 29, 2010, 03:45:51 AM by J_Speegle »
Re: 1967 Pulleys
« Reply #1 on: January 28, 2010, 08:50:53 PM »
Since many of the pulleys were not stamped (into the metal) with the engineering numbers you will likely need what other applications used the same pulleys and the specs so you can measure any you find. For you I suggest looking up what is listed in the Add/Delete sheets then cross referencing those in the MPC so find the shared application and the measurements.
Re: 1967 Pulleys
« Reply #2 on: January 28, 2010, 09:44:40 PM »
The part number is: C1AZ-6A312-C.  My documentation states there is no casting number for this pulley.
This was also used on 390 GT engines.
Re: 1967 Pulleys
« Reply #3 on: January 29, 2010, 02:15:45 AM »
That is the correct part number for the crank pulley. The casting number on the crank pulley is C1AE -6312-A. Bob
