Author Topic: VIN on Engine Compartment sides one number off?  (Read 2751 times)
Offline Turnall
« on: January 21, 2013, 08:34:29 PM »
6T07T235364 is the VIN for my Mustang but the right side (if sitting in the drivers seat) is one number off from this.  Shouldn't these be the same?
Allen
priceless
  • Guest
Re: VIN on Engine Compartment sides one number off?
« Reply #1 on: January 21, 2013, 09:11:00 PM »
Yes, all VIN's should match. Not uncommon though for Ford to make VIN mistakes.  I had a '66 coupe 289 that I drove daily from 1981-1989 that the VIN on the drivers side apron and the VIN on the drivers door was off one letter, the engine code on the door was T(6 cyl) and the one under the hood on drivers apron was C (289,V-8). All the rest of the VIN  matched.
Also, I read in Mustang Monthly back years ago that approximately 50 vehicles(Mustangs,fairlanes,etc) on the assembly line was stamped with the same VIN.
Offline Turnall
« Reply #2 on: January 21, 2013, 09:13:59 PM »
Here are pictures of the VIN...The first picture is the correct VIN (buck tag, door, etc.).
« Reply #3 on: January 21, 2013, 10:32:51 PM »
Turnall - short answer as mentioned is yes the purpose fir identification purposes is that they all should match. Hopefully the one that is visible in the fender cut out is one of those that matches the paperwork and door tag (for the lazy DMV worker ;)
....Also, I read in Mustang Monthly back years ago that approximately 50 vehicles(Mustangs,fairlanes,etc) on the assembly line was stamped with the same VIN.
Have seen a few "corrected" VIN's  if true (the fifty car story) I'm sure they corrected them - if not that's allot of crushed cars.
Offline Turnall
« Reply #4 on: January 21, 2013, 10:51:35 PM »
Yes Jeff, the 365 is on the passenger side apron and is covered up!  8)
Allen
priceless
  • Guest
« Reply #5 on: January 22, 2013, 09:53:36 AM »
Never said in the article if corrected, was just talking about Ford VIN mistakes in the first generation.
« Reply #6 on: January 22, 2013, 10:19:38 PM »
Must have been a new worker in that position that day - not like they hadn't been stamping VINs on the inner panels for years prior
Do you remember the author of the article? Guess in Jim Smart
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« Reply #7 on: January 23, 2013, 08:01:07 AM »
If it happened, it could have been a disgruntled guy that was about to quit.
66 Metuch Conv
Nightmist, Std Blu Int
Offline C5ZZ
« Reply #8 on: January 23, 2013, 09:18:58 AM »
Between the VIN and the trim code you have a unique one of a kind car!
At least the different number is covered up, I saw a car one time that
had the exposed VIN double stamped with two numbers, different
engine codes.
MCA # 00945
Rangoon Red/Red Interior
priceless
  • Guest
« Reply #9 on: January 23, 2013, 10:13:05 AM »
Lord, Jeff, that's been several years ago, maybe even 10 or more years.
I have every issue of Mustang Monthly since its beginning , I'll get the time, I'll go back and see if I can find that issue, and I think it was Jim Smart.
