Author Topic: 1965 1966 Restored Door shells  (Read 3695 times)
Offline criscoelectric
« on: July 28, 2009, 07:13:08 PM »
I have a few door shells for sale that have been professionally restored and are ready for paint. They are date code correct for 1965 -66 years.
These were chemically dipped to remove all old paint and rust and then were gone over for dents/ dings before being primered with an epoxy primer sealer.
The infamous front lower corner was given particular attention to make sure all old deterioration was removed before the primer sealer was applied.
They can be shipped anywhere in the continental U.S.
They are in EXCELLENT condition.  Of the 5 I have, 3 (1 left,2 Rt) are  10s. The other left and Rt doors are 9s as they have a slight dent near the weatherstripping line at the hinge side.  Neither would be noticeable once the trim and panels were installed.  The 10s are $500 each, the 9s are $450 each.  Please email for detailed pics.
« Last Edit: July 29, 2009, 09:53:21 PM by criscoelectric »
1965 Coupe, 1995 GT Convertible, 1998 SVT Cobra
Offline C5ZZKGT
  • Gold Level Subscriber
Re: 1965 1966 Restored Door shells
« Reply #1 on: July 29, 2009, 09:48:41 PM »
It is my understanding that the hinge bolts are different sizes from 1965 to 1966.....I guess it wouldn't make any difference if a car wasn't being built for concours competition though.
« Reply #2 on: July 29, 2009, 10:06:31 PM »
You are correct. I believe the 65 used a 3/8" bolt whereas the 66 utilized a 5/16" bolt. (or was it the other way around...I can't remember)
 The hinge mounting plates can be readily changed from one size to the other.
« Reply #3 on: August 08, 2009, 08:55:04 PM »
UPDATE:
DOOR SHELLS ARE AS FOLLOWS;
Door #1: Date Code 5 21 2W,  Paired with door #4 (see below), Driver side, 5/16 hinge,  Quality is "10"
Door #2: Date Code 10 13 W2, Passenger side, 5/16 Hinge, has been reskinned, Quality is "10"
Door #3: Date Code 11 2 B2, paired with door #5 (see below), passenger side, 3/8 hinge,  Quality is "10"
Door #4: Date code 5 14 2W, Paired with door #1, passenger side, 5/16 hinge,  has small dent at hinge side near weatherstripping line, not repaireable but hard to see when door is complete,  Quality is "9".
Door #5: Date code 11 30 B2, paired with door #3, Driver side, 3/8 hinge, has been reskinned,  has small dent at weatherstrippng line near lower hinge, can be seen but not readily noticeable,  Quality is "9"
Detailed Pics can be furnished to serious buyers.  Email criscoelectric@yahoo.com
Please be specific as to which door(s) you are interested in.
