Author Topic: 1966 January Metuchen door jamb bolt type  (Read 3309 times)
Offline tomtri66
  • Bronze Level Subscriber
« on: January 17, 2013, 01:48:56 PM »
Can anyone help me out with what type of window track bolts in the door jambs were used in Metuchen in Jan 1966?  Over the years and with previous owners I ended up with a mismatch on the car and can't determine if they were originally disc type or star washer type.  I believe disc type, as the passenger side is an original door and that is what is predominantly there, but not sure.  As always, thanks very much for all of your knowledge and sharing. :)
Tom
C/O    762
4        A20     6T07T194XXX
65A       Y        22
Re: 1966 January Metuchen door jamb bolt type
« Reply #1 on: January 17, 2013, 05:08:17 PM »
If the passenger side is original and with disc washer bolts, I would use that on the driver side.  Most likely disc SEMS.
« Reply #2 on: January 17, 2013, 09:04:23 PM »
Per the 66 Mustang Assembly Manual, AM0011 pg33, I think you want item "J", 378695-S2 5/16-18X1/2hex with an external lock washer. These look like 64-65 fender bolts without the lead point. Look at the attached and see if these are the ones.
Just because you got a certain type of item on one side that is supposed to be "original" and a different one on the other, do not assume that the "original" is correct.
I strongly recomend you get a set of 66 Mustang assembly manuals, plus the 64 Chassis and 64-65 Weld and Sealant.
Offline tomtri66
« Reply #3 on: January 20, 2013, 06:47:38 PM »
Thanks Charles and Jim.  I definitely have to pick up a set of assembly manuals.  I vaguely remember discussion on here that there was different fasteners used per plant time period.  Maybe mistaken....
C/O    762
4        A20     6T07T194XXX
65A       Y        22
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« Reply #4 on: January 20, 2013, 07:07:48 PM »
Mine is all original MARCH Metuchen.  Will that be close enough to help you?
66 Metuch Conv
Nightmist, Std Blu Int
Offline tomtri66
« Reply #5 on: January 21, 2013, 12:00:06 AM »
Absolutely Bryan.  Does yours use the disc type as I suspect?
Tom
C/O    762
4        A20     6T07T194XXX
65A       Y        22
Offline bryancobb
  • 2009 Ridn' Around
« Reply #6 on: January 21, 2013, 06:47:39 PM »
I'll look when I get home.
66 Metuch Conv
« Reply #7 on: January 21, 2013, 10:42:26 PM »
Looks like they went to the smooth washer in March (only going by projected build dates of course)
Here are a couple of examples from before that time period
6T07C121548
6T09A167167
Offline bryancobb
  • 2009 Ridn' Around
« Reply #8 on: January 21, 2013, 11:23:22 PM »
Here's mine.  I was very methodical when disassembling and reassembling stuff to make certain I didn't get bolts mixed up.  I'm 90% sure these are the bolts that came from the factory.
March 15 Scheduled.   Hmmmmmmm!  Just realized my car has an extra hole behind the tag?
6T08C223904
« Last Edit: January 21, 2013, 11:27:00 PM by bryancobb »
66 Metuch Conv
Offline tomtri66
« Reply #9 on: January 25, 2013, 08:49:18 AM »
Hmmm...I am wondering if the changeover was before March and sometime in January?  My passenger door, which I know is original, has the same disc type as Bryan's.  I wonder if the red fastback built the same week as mine that Charles is restoring has the same.  Charles? :)
C/O    762
4        A20     6T07T194XXX
65A       Y        22
« Reply #10 on: January 25, 2013, 09:36:54 AM »
It will be a while before I can answer that question.  A lot of the parts for that car, including fasteners are still bagged/tagged, awaiting restoration.
Offline tomtri66
« Reply #11 on: January 25, 2013, 12:46:37 PM »
Ok no problem.  Thanks Charles.
C/O    762
4        A20     6T07T194XXX
65A       Y        22
