Author Topic: 1966 6 cylinder coupe spindles  (Read 10005 times)
Offline C5ZZ
Re: 1966 6 cylinder coupe spindles
« Reply #15 on: January 18, 2013, 10:23:40 PM »
Another thing to check would be the tapered stud on the tie rod,
compare the outer ones that go into the spindle to the inners, they
should be the same diameter, I think you will find the C6OA spindles
have a larger tie rod end hole so maybe they swapped out the outer
tie rod ends along with the spindles.
MCA # 00945
Rangoon Red/Red Interior
Offline Turnall
« Reply #16 on: January 18, 2013, 10:33:04 PM »
Ok, so there will be slack in the new tie rod end where it goes into the spindle.  I will check this tomorrow...
(Old tie rod ends have been thrown away I think...couldn't find them.)
Offline C5ZZ
« Reply #17 on: January 18, 2013, 10:39:52 PM »
My guess is that you will find slack in them, if thats the case then I would say that
you need to get another set of the correct spindles with backing plates, hubs, drums etc.
Charles had mentioned that he may have some, if he doesn't let me know I have them.
MCA # 00945
Offline Turnall
« Reply #18 on: January 19, 2013, 01:04:54 PM »
Ok, here is the picture.  Pretty obvious that the spindle is not the correct one for the 6 cylinder tie rod end.  You will notice the threads are completely through the spindle and still loose.
Offline C5ZZ
« Reply #19 on: January 19, 2013, 02:55:49 PM »
That seems to verify it. The hub/bearings you have which fit on this spindle should be
too big for the correct 65/66 6 cyl spindle, not sure about the backing plate but
thinking its different as well.
MCA # 00945
Offline Turnall
« Reply #20 on: January 19, 2013, 03:34:13 PM »
If anyone has a set of these (full set of spindles, hubs, etc.), please let me know and what you would take for them and what shipping would be.  I will check the classifieds to see if any are on there.  Again thanks for all the contributions, sure helps to have knowledgeable people helping along the way.
Allen
« Reply #21 on: January 20, 2013, 01:30:05 PM »
PM sent regarding parts...
Offline drummingrocks
« Reply #22 on: January 20, 2013, 01:33:33 PM »
I have a complete set of spindles, hubs, and brakes I took off of a driveable '65 coupe when I converted it to a V8.
Offline Turnall
« Reply #23 on: January 20, 2013, 08:53:54 PM »
Thanks all, C5ZZ and I are working a deal on a set...
« Reply #24 on: January 22, 2013, 12:03:04 AM »
Guess I didn't send a PM fast enough.  Wish I would have known you were going to look elsewhere, would have saved me the time of looking for them.
Offline Turnall
« Reply #25 on: January 22, 2013, 01:22:40 AM »
My apologies, didn't mean to put anyone out...
If someone can explain who gets the 1st opportunity to sell parts, I would be grateful...
Allen
Offline Turnall
« Reply #26 on: January 22, 2013, 01:35:26 AM »
Charles, I just saw your message...I will take your set as well (all of it)...
Allen
« Last Edit: January 22, 2013, 01:37:39 AM by Turnall »
« Reply #27 on: January 22, 2013, 01:39:24 AM »
Allen
It doesn't really matter to me, I don't sell parts for a living, this is just extra stuff that I have accumulated.  If you read back through this thread, you will see that I offered that I might have what you need and C5ZZ said to contact him if that didn't work out.  There isn't any rule about who gets 1st opportunity to sell, but a little common courtesy is appreciated.
Offline Turnall
« Reply #28 on: January 22, 2013, 01:43:44 AM »
I hope you got my message...
Allen
