Author Topic: 65 Firewall Pads (Specifically San Jose)  (Read 10253 times)
« on: January 16, 2013, 07:29:37 PM »
Trying to see if I can determine some general or specific change over periods for each of the different firewall pads used at San Jose in 65.
We realize that the typical/normal pad was produced and supplied by a different  sub contractor than the other plants (like many parts) characterized by a "dimpled" or "off set pegboard" surface
Major difference appears to be the punch outs for the AC hoses. So far I've got the
1- No punch out
2- Vertical oval ended punch out
3- Vertical square corner punch out
4- Horizontal (angled up at passenger end) oval ended punch out
Here are a few examples
No punch
Some may notice the early clutch rod seal in the example below
« Last Edit: February 07, 2018, 06:41:54 PM by J_Speegle »
Re: 65 Firewall Pads (Specifically San Jose)
« Reply #1 on: January 16, 2013, 11:57:34 PM »
Jeff,
 My Oct 65 San Jose build "K" has an oval hole but it's at a 70 degree angle. It's too cold to take a picture tonight but I'll wrap myself in a parka and hit it tomorrow, along with my Oct 65 San Jose build hardtop. It's cold in Santa Clara -  ;)
« Reply #2 on: January 17, 2013, 01:50:31 AM »
Jeff,
Being a 66 model I would expect you to have the #4 version - thanks
« Reply #3 on: January 17, 2013, 08:41:58 AM »
The red '65 SJ convertible I'm putting together now is in the 206xxx range, it had the sideways oval punch-out for a/c lines.  Something I noticed about that original firewall pad was it was a little more shiny than the earlier ones I have seen.
Offline Brant
« Reply #4 on: January 17, 2013, 04:38:58 PM »
Jeff,
My June '65 production GT350 has the vertical rectangular style punch out.
My late March '65 one has the same style.
The early Dec. '65 production GT350's that I have observed have the one without any punch out.
Oh, and anyone has one of the vertical rectangular SJ style ones, I sure could use a nice one!
« Last Edit: January 17, 2013, 04:44:26 PM by Brant »
Offline trucktricksdon
    • Direction Auto & Truck Accessories
« Reply #5 on: January 17, 2013, 04:47:01 PM »
I took some photos of my November 64 SJ, A code coupe. DSO was Dallas. VIN# 156xxx. Appears to have been hacked so probably no cut out.
« Last Edit: January 17, 2013, 05:10:21 PM by trucktricksdon »
Offline PraireBronze
« Reply #6 on: January 17, 2013, 05:17:40 PM »
October '64 SJ fastback...  Same here.  Mine looked like someone jabbed a screwdriver through it until there were big enough holes for the hoses, and then jabbed it some more for good measure.
- Tim -
1965 Prairie Bronze 2+2 (under construction)
Build Oct '64 San Jose
289 4V Automatic Transmission (A-code clone :P )
Black Std Interior
AC, PS, Style Steels, 1" Drop, Konis
Aluminized 2 1/4 Exhaust, Tri-Ys
« Reply #7 on: January 17, 2013, 09:07:29 PM »
Here are pictures of my Oct 15, 1965 hardtop and Oct 18, 1965 K Fastback firewalls. Both are San Jose cars.
Offline 6S280
« Reply #8 on: January 17, 2013, 10:19:32 PM »
Firewall pad picture from my early '66 Shelby #280.
« Reply #9 on: January 18, 2013, 08:21:43 PM »
A picture of my San Jose May 11 build 65 GT Fastback, square cut vertical. Should we also look in the engine compartment for the corresponding A/C hoses' access?
« Last Edit: January 18, 2013, 08:23:21 PM by jwc66k »
Offline buckeyeresto
« Reply #10 on: January 19, 2013, 03:48:20 PM »
Those firewall pads just aren't san jose seen them in many early dearborn cars.  Just took apart an original 64 1/2 pace car coupe built april 17th 1964 with the pad you show in the pictures
« Reply #11 on: January 19, 2013, 06:55:08 PM »
Jeff does a lot of research on Mustangs. I don't know what his objective was in this case, I assume looking for a transition date from one type of pad to another, but specifically as installed in the San Jose assembly plant. His quest may apply to Shelbys for that matter. Owners of Mustangs from other plants my be asked to do a similar survey on pads or other components.
Offline jstefanick
    • Restoration Pics
« Reply #12 on: January 20, 2013, 03:24:42 PM »
This is from my Oct 18, (K 18) San Jose build '66 Convertible. Looks like a #4- horizontal oval to me too.
My firewall pad looks a bit different, in that it has the square imprint other than the dimple look- is it original?
6R08T120933
K18 (Oct 18, 1965)
« Reply #13 on: January 20, 2013, 10:04:23 PM »
Haven't seen one like that before.
Offline ChrisV289
« Reply #14 on: January 23, 2013, 10:50:47 AM »
I looked at mine yesterday (Oct 1964 SJ) and i have two distinct round holes cut out in the firewall pad.  I'll post a picture later when I get home...
2009 V6 Mustang Coupe
