Author Topic: Firewall pad  (Read 7365 times)
Offline Sunlitgold68
Firewall pad
« on: January 26, 2010, 08:31:03 AM »
Are 67 and 68 firewall pads the same?
How many firewall pad retainers are there?
« Last Edit: January 26, 2010, 09:49:22 AM by Sunlitgold68 »
8T01C204XXX
Built May 14th, 1968
Re: Firewall pad
« Reply #1 on: January 26, 2010, 04:02:15 PM »
Don't recall but don't know of a difference - possible someone else will speak up. The are differences depending on if the car had AC and where the car was assembled
Re: Firewall pad
« Reply #2 on: January 26, 2010, 04:51:17 PM »
Difference between retainers 67 and 68 and the texture of the pad between San Jose and the other plants but that is all I can think of.Bob
Offline sparky65
Re: Firewall pad
« Reply #3 on: January 26, 2010, 07:34:38 PM »
Are the repro Firewall Pad's any good?  It sounds like your looking for a good doner car to steal one from.  It sounds like it could be hard to find a good original.  Mine was ripped and I don't think these things are repairable.
Steve
2009 Black GT Coupe
Re: Firewall pad
« Reply #4 on: January 26, 2010, 07:46:31 PM »
As always IMHO its great if you can find and use an nice original one (sure puts a smile on a judges face) but lacking that, what some are doing (and what I did) for a non San Jose style dash pad is to purchase a repo and apply some sound deaedner/undercoating spray to get the texture. I "rained" down the spray from about three feet above, attempting to get it to hit with a splatter/globby look
Re: Firewall pad
« Reply #5 on: January 26, 2010, 07:56:53 PM »
I might have found a nice original. That sounds like a good idea though.
8T01C204XXX
Offline gtamustang
  • CPM
Re: Firewall pad
« Reply #6 on: January 27, 2010, 04:01:06 PM »
The 67-68 reproduction firewall pads are crap! Nothing on the repro pad is close to the original...materials, texture, thickness, shape, pre-punched openings and lame fasteners. It will take considerable time to fit and get components (like the fuse box, pedal washer) to fit. IMO, use one if you are desparate!
Regards,
Pete Morgan
Re: Firewall pad
« Reply #7 on: January 27, 2010, 04:09:32 PM »
Regards,
Pete Morgan
++11.   Bob
Offline sparky65
Re: Firewall pad
« Reply #8 on: January 27, 2010, 06:53:28 PM »
Regards,
Pete Morgan
I see NPD has two styles.  A cheaper version and a 'molded' version.  Do you know which type you got?  Or are they all bad.  I am going to dig out my old one and see if it cant be repaired with undercoating.  Doesn't hurt to try I guess.
Steve
2009 Black GT Coupe
Re: Firewall pad
« Reply #9 on: January 27, 2010, 07:07:34 PM »
Even the "concours" ones for $140 are worthless from what I have been told.
8T01C204XXX
Offline TLea
Re: Firewall pad
« Reply #10 on: January 27, 2010, 08:11:19 PM »
The expensive ones are just that, expensive. They still look and fit lousy. I have a mint SJ pad I'd happily trade for a NJ pad of equal condition
Re: Firewall pad
« Reply #11 on: January 27, 2010, 10:17:30 PM »
What's the difference in San Jose pad verse NJ pad for 68?
8T01C204XXX
Re: Firewall pad
« Reply #12 on: January 28, 2010, 12:38:55 AM »
Texture
Dearborn and NJ pad had a surface that was a splattered one
San Jose had evenly spaced raised dots in nice rows
Offline sparky65
Re: Firewall pad
« Reply #13 on: January 30, 2010, 05:30:40 PM »
I dug out my 67 original but could only locate two holes for retainers.  THe problem is i am missing the entire part to the left of the steering wheel where from looking at some pictures i think there were two.  They were the metal sawtooth verity.
Steve
2009 Black GT Coupe
Re: Firewall pad
« Reply #14 on: January 30, 2010, 07:16:23 PM »
At least 3 with out looking on the retainers for the pad. The saw tooth retainer had a 65 and up to mid 66 variety and a mid 66 through 67 slightly different saw tooth style variety. Hard to tell the difference unless they are side by side . Very small difference. The good news is I saw where Dearborn classic sells the saw tooth variety but under a Galaxie application.  It was junk yard only part until now. Bob
