Author Topic: What is the correct radiator for my car (SJ 68 J code with A/C)  (Read 2909 times)
Offline tim_morrison82
    • Click Here for My Project
« on: December 26, 2012, 01:53:30 PM »
I am looking for info regarding the correct radiator for my car.
I have a/c, and auto, and p/s. I also have top and bottom radiator clamps which i believe are only found in 24inch radiator cars? I do not know if they are original, but they do look old.
Current radiator is a 24inch reproduction or replacement? No markings or partnumbers or stamps in any part of the radiator tanks or supports. I am assuming they put that in to replace a similar sized rasiator, but i could be wrong.
I havent been to the shed recently, but need do go through my boxes. Would there be a date stamp on the top radiator clamp that i could cross reference with my other panel dates to see if that is an original part?
I keep being reminded that 24inch radiators were only found in desert cooling optioned cars, but i believe that this is not always the case?
« Last Edit: December 28, 2012, 12:01:52 AM by J_Speegle »
Re: What is the correct radiator for my car
« Reply #1 on: December 26, 2012, 01:56:39 PM »
Sorry, thought i had a signature on this site.
Car is san jose j code 68, built mid dec 67.
Offline Oz390
Re: What is the correct radiator for my car (SJ with A/C)
« Reply #2 on: December 26, 2012, 07:58:09 PM »
Never seen a "desert cooling" option, most Ford docs I've seen note "extra cooling" or a/c applications.
Ford shop manual calls out a 24" radiator for 289/302 for extra or a/c.  Other refs I have note 24" for various applications as well.  So it appears they were used for a few applications.
Unsure what prompted the "extra cooling" option/requirement vs. a/c.
8R03S : 76A I 2A 15M 72 5 U
« Reply #3 on: December 27, 2012, 08:08:50 PM »
Have never heard the "desert cooler" description applied to 67-up only in 65-66 which was a very different looking unit. Instead I think you may be referring to the "extra cooling" as often seen listed in Marti reports
For your application I looked through my stuff and found a buildsheet from a mid December J code, auto, PS, AC car that seems to match your care pretty closely. That buildsheet listed the original radiator as a C8ZE-F marked unit.
Looking at the Illustrated Parts Guide from the period it shows that the replacement for a J code with AC (listed as an extra cooling unit) was the wider version with the top and bottom clamps
« Reply #4 on: December 27, 2012, 09:20:38 PM »
I have only heard the desert cooler description used by after market companies and not by Ford in any literature.
« Reply #5 on: December 28, 2012, 12:01:31 AM »
Think I've got a reference to them in one or two documents will have to find and post them - in another thread since its not a 67-up reference ;)
Looking at my pictures the design of the radiators on SJ cars changed - might be a change in supplier - who got the contract that year but still have allot of Modine stamped examples.  Have to look deeper into the difference for an explanation
« Last Edit: January 14, 2013, 08:11:42 PM by J_Speegle »
Re: What is the correct radiator for my car (SJ 68 J code with A/C)
« Reply #6 on: December 28, 2012, 04:51:22 AM »
just to confirm, the C8ZE-F is a 24inch radiator?
Offline TLea
« Reply #7 on: December 28, 2012, 09:14:49 AM »
Maybe. You forgot to tell us which transmission you have.
C8ZE F is for auto
C8ZE E is for standard trans
Also SJ radiators are different than Dearborn/NJ radiators. You want one with the W MO on top tank
« Reply #8 on: December 28, 2012, 01:45:47 PM »
Yes
Maybe. You forgot to tell us which transmission you have..........
Second line of his first post ;)
« Reply #9 on: December 29, 2012, 03:55:55 AM »
I did a search online for pics and saw a 7L dated one on ebay and nearly died, however, it was an old picture...
Would have been perfect!
I have my eye on 2 potential radiators now, hopefully i can track one down close to my date. Or at least from the correct plant. I did a search on here for that part number and it came up with some pics to id the different radiators used in the different plants, so fingers crossed one turns out to be good.
I am also on the lookout for a shroud to suit. I have had 1 quote from a shop for an original, and its not cheap. But there cant be too many left
Offline TLea
« Reply #10 on: December 29, 2012, 06:37:17 PM »
The shrouds are as hard to find as the big block ones (they are a one year part) but fortunately they dont get big block prices. Still be prepared to pay 2-300 for a nice one.
