Author Topic: 67 Shelby Opened Hood Rod Support  (Read 2229 times)
Offline ceswert
  • Silver Level Subscriber
« on: December 26, 2012, 12:32:46 AM »
Did any 67 Shelby's use the swing up rod to support the hood when raised? I read or heard somewhere these were used for a short time. Did 1966 cars use them? I am wondering if they were a carried over into '67.
67' Shelby GT 350 nm blue/4sp/#0089
07' Shelby Super Snake 725hp/white/#0073
71' Mach 1 429cj grabber blue/4 sp./ac
Re: 67 Shelby Opened Hood Rod Support
« Reply #1 on: December 26, 2012, 01:21:40 AM »
There are a few reported 67 prop rod hoods. Very few. It was not a good solution. The 67 with the steel innerstructure used the standard Mustang spring (hoods were heavy with steel inner structure) . The smaller diameter light springs would not hold a steel innerstructure hood up. With the steel innerstructure the hoods didn't warp with the tension of the heavy standard Mustang springs like they would on a all fiberglass hood. The steel innerstructure hood was more labor intensive and more costly because of that and added materials . That was the main reason it was phased out.The later all fiberglass hoods used the light springs.
Offline ceswert
« Reply #2 on: January 17, 2013, 10:26:31 PM »
Thanks Bob. I found one prop rod described as a 1965, 350 part. I looked at a few images of 65's with no rod in sight. Might this rod be for 67's because of the hefty early steel hood frames? If I were to put a prop rod on my car would I have to locate the correct hinges for this set up? Lastly, is what I'm trying to accomplish be considered correct for my car? Maybe I'm going too far!
Thanks!
« Reply #3 on: January 20, 2013, 11:24:37 PM »
Don't recall a hole(s) ion your radiator support plus other cars in your group don't have the feature. Think your getting distracted ;)
« Reply #4 on: January 21, 2013, 03:46:20 AM »
I would not add prop rod if it were my car.
Offline ceswert
« Reply #5 on: January 29, 2013, 12:58:14 AM »
Agreed and thanks!
