Author Topic: Leaf Spring Rebuild Question  (Read 2562 times)
Offline G Wood
« on: January 25, 2010, 10:49:30 AM »
Any advice for removing the steel sleeve inside the front spring mount on a leaf spring. When you remove the rubber bushing, the sleeve stays in the spring. To insert the new bushing and sleeve, the old sleeve must come out.
Re: Leaf Spring Rebuild Question
« Reply #1 on: January 25, 2010, 10:52:16 AM »
chuck it up in a vise & cut the old rubber off.
Offline JKWilson
« Reply #2 on: January 25, 2010, 11:49:04 AM »
If you've already gotten the rubber portion out, IMHO, the hardest part is done! You can simply use a chisel to split the steel sleeve. I split it at the area where the spring eye wraps over and forms a gap. That way you won't be hitting the spring. Once it's split, the sleeve taps out easily.
Offline G Wood
« Reply #3 on: January 25, 2010, 03:20:06 PM »
That is kind of what I was thinking, will give it a try tonight.
