Author Topic: Differential Markings Picture Mar 66 Metuchen  (Read 3102 times)
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« on: December 18, 2012, 08:04:42 AM »
Is there a chance of anyone have picture(s) of the rear end markings for a
C-Code car near mine in production?  Standard 8".
66 Metuch Conv
Nightmist, Std Blu Int
Re: Differential Markings Picture Mar 66 Metuchen
« Reply #1 on: December 18, 2012, 08:19:56 PM »
Byran send me an email and I supply right after the holiday. If I post a bunch they will end up on everything - likely a Boss :( at some point, as we've seen before
PMM= Paint Mark Migration ;)   - lol
Offline bryancobb
  • 2009 Ridn' Around
« Reply #2 on: December 19, 2012, 08:17:47 AM »
You can send me an ANTI-PMM PM to ........b r y a n A T l l i n d D O T c o m  ..........!  Thanks
66 Metuch Conv
« Reply #3 on: December 20, 2012, 01:56:45 AM »
Will do -
Offline bryancobb
  • 2009 Ridn' Around
« Reply #4 on: December 25, 2012, 09:08:02 PM »
Just a little Bumpy Bumpy
66 Metuch Conv
Offline rockhouse66
« Reply #5 on: December 26, 2012, 08:39:12 AM »
Wouldn't all the diff paint markings be the same/similar since they were all assembled at the same place or were some of these markings assembly line markings?  I thought the diffs came to the plants fully assembled with the rear axle and brakes and were installed as a unit.
'66 GT FB
« Reply #6 on: December 26, 2012, 02:54:20 PM »
Email and file sent
Happy New Year
Many of the marks would be the same IMHO if compared to other rearends built at the same assembly plant around the same time. Not sure how many plants for had in the mid/late 60's to build rearends other than Sterling (think they were operational them)  Most of the marks suggest identification, assemblers, inspection. But IMHO there are others that were applied at the car assembly plant for their purposes
Offline 51f1truck
« Reply #7 on: December 27, 2012, 09:56:04 AM »
Bryan:
I redid my original 8" last in the spring.  It is from a 1965 Oct build.  I was careful during cleaning and only found this one prominent mark on the back.
Fred
Offline bryancobb
  • 2009 Ridn' Around
« Reply #8 on: December 27, 2012, 10:31:16 AM »
Thanks guy.
Bryan:
Fred
66 Metuch Conv
« Reply #9 on: December 27, 2012, 02:24:49 PM »
Fred - what plant was that car from??
And we're assuming that the Oct date if from the door tag (projected build date)   ;)
Offline 51f1truck
« Reply #10 on: December 27, 2012, 08:56:34 PM »
It is from Metuchen.  Build date is from the build sheet I found under the dash.  I also have the buck tag.
VIN is : 6T08C135871
« Reply #11 on: December 27, 2012, 11:56:56 PM »
It is from Metuchen.  Build date is from the build sheet I found under the dash.  ...............
Guess we need to compare (I've not so far) buildsheet and buck tag dates to actual build dates to see if there is a difference
