Author Topic: 390 timing  (Read 914 times)
Offline V8_bloke_28
390 timing
« on: December 18, 2012, 06:38:57 AM »
Hi, I have a 67 mustang 390 auto with air and was wondering what the timing should be once the vac hose has been disconnected and plugged off. The engine is stock but it has an old electronic ford dizzy?
Re: 390 timing
« Reply #1 on: December 18, 2012, 09:02:03 PM »
Believe if its not equipped with Thermactor its 10 degrees BTDC
Start there and if you get any ping under load (full throttle) then back off the advance by a couple of degrees until it disappears
« Last Edit: December 18, 2012, 09:11:35 PM by J_Speegle »
