Author Topic: How to decode hood hinge dates ?  (Read 4112 times)
Offline cjmustangman
« on: December 13, 2012, 03:00:52 PM »
I'm not sure if this is the right place to post this but will start here and Jeff can move it to where it belongs.
So I have an assortment of hood hinges and am trying to sort them out by dates, some have just have stamp  like 8 3 3 and others start with OB 4 9D2 or OB326 2
I'm thinking that they translate to month, day, manufaccturer and shift maybe ???
Is there no Year date stamped on the hinges ?
Also I see a 2 digit number stamped on the opposite side of the date code , what does this represent ?
Arild
Re: How to decode hood hinge dates ?
« Reply #1 on: December 13, 2012, 04:20:39 PM »
Pictures would help define the years in question, there are subtle differences in designs as well. A date code is usually month, day and shift, all numbers, with a plant code, if any, as letters.
Offline TLea
« Reply #2 on: December 14, 2012, 06:23:08 PM »
read the first 2 numbers after OB
4 9= april 9
3 26= March 26
D 2 is Dearborn stamping plant 2nd shift
« Reply #3 on: December 15, 2012, 01:05:04 PM »
Thanks Tim,
Heres a couple of pictures
Arild
Offline TLea
« Reply #4 on: December 19, 2012, 06:26:00 PM »
What interesting about 69 hinges is you will sometimes have a date on the top flange that attaches to hood and another in the location you show. Often they arent even close, I restored one the other day that was mid Jan on top and early March on the side
« Reply #5 on: December 20, 2012, 12:12:32 AM »
arild your top photo is 67-68 & bottom is 69 style hinge
« Reply #6 on: December 20, 2012, 04:51:37 PM »
thanks Ed,
I guess I'd better change these hinges then...
How do you tell the 67/68 from the 69/70 version ?
I was led to believe the OB dates were 69 and later ???
Arild
« Reply #7 on: December 21, 2012, 02:09:10 AM »
thanks Ed,
The top section of the hinge (guess I could post pictures but its late ;)  where it attaches to the hood. Later ones have a dip or edge that has a dip in it to clear the hood substructure where the earlier version is straight from one end to the other
« Reply #8 on: December 21, 2012, 10:54:09 AM »
This is why ford changed part # from C7ZZ to C9ZZ & it has nothing to do with the X rivets to the O rivets as that change showed up in early 70 production. You can use the later version on all cars but if you use the c7 version on a 69-70 hood the top angle area between the top 2 rivets will rub on hood crossbraceing & that is why that top angle part is notched out on c9zz hinge.  I have seen the c9zz style on late 68 KRs as ford may have ran out or just used up C7zz version & started using the c9zz type & that is why you never find the c7zz nos only the c9zz service nos hinges out there.
« Reply #9 on: December 21, 2012, 02:19:39 PM »
Thanks Jeff and Ed,
This is what I love about this forum, ask and you shall recieve.
Arild
